Results 1 to 20 of 20
    Jan 2019
    Hunter Valley NSW Australia
    Default Negatives of mounting front Camera behind windshield?
    Santa brought me a dual camera system https://www.thinkware.com/Products/Dashcam/M1 . Rear camera was very easy to mount, but the front has me stumped.
    I am looking at mounting it behind the front windshield, but wonder if that has consequences like
    • too blurry in rain,
    • reflected light during night riding,
    • contending with bug gizzards obstructing the view,
    • dust buildup behind and in front of the windshield,
    • Windshield shake affecting the image quality,
    Plan B is to make a bracket and mount it just beneath the front windshield.
    Plan C is to mount it on the mirror and notch the casing of the mirror to accommodate the cable (8mm in dia).
    Any input is appreciated
    2017 RTL
    2017 RTL , White
    Apr 2019
    Clinton, MS
    Interesting choice, had not seen that one before. Nice to see more options one the market.
    I debated mounting behind the windshield, but came up with the negatives that you did.
    I just built a small bracket to mount my front Innovv camera. I think it was the best decision and has caused no concern in 20,000 miles.
    Apr 2019
    Clinton, MS
    Maybe one day i will learn how to post a picture correctly.
    Oct 2020
    Arizona
    Take photo's in landscape mode. Or edit them to be wider than height.
    Edit example. I down loaded your photo and open it in Microscoft "Picture It", rotated it correctly and then cropped it. Chris
    Sep 2020
    Orlando, Florida
    Just visited the Thinkware site. Could not find any information related to how weatherproof their products are. I would expect the rear to be as they are normally mounted outside, but most front dash cams are designed to be mounted inside a vehicle. Is that information included with any of your paperwork?
    Sep 2020
    Middletown, NJ
    I mounted my Garmin Virb in front of screen using 3M 2-sided tape on the lower cowl. Virb is controlled via the Zumo GPS.
    2020 RT base , Chalk White
    Oct 2020
    Arizona
    BTW, we got a Spyder RT that color for Christmas.
    Apr 2019
    Clinton, MS
    Quote Originally Posted by Snoking1127 View Post
    That's basically what I did to the two that are oriented correctly. My comment was more directed to the fact I was unable to delete the two incorrect pics.
    Oct 2020
    Arizona
    Go to edit, go advanced, manage attachments and scroll down and you can delete attached photo's individually. Chirs
    Apr 2019
    Clinton, MS
    Thank You, Thank You, Thank You.
    Now if my pea brain will just remember that tip next time it happens. Previous post pics now corrected.
    Bossier LoUiSiAna
    Quote Originally Posted by Lynn8964 View Post
    Wondered same thing did some digging they have one under Motorsport : M1 better suited & some other features
    https://us.thinkware.com/m1/
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jan 2019
    Very tidy effort there.
    2017 RTL
    2017 RTL , White
    Jan 2019
    Yes the M1 is what they refer to as an ATV camera suitable for outdoor recreation vehicles.
    2017 RTL
    2017 RTL , White
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    Quote Originally Posted by askitee View Post
    I have my GoPro mounted behind the windshield in the center of the dash. Seems to me most of the negatives listed are just as negative if the camera is mounted out in the open. I’ve never experienced problems with reflected light. My windshield doesn’t shake.
    2022 Plasma Red, F3 Limited, Special Series
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    My two cents, if i had the desire to put a camera on my spyder, I would mount it, behind the radiatorgrille, only downside I can think of, is that the camera would sit to low. Last summer I saw a ducati driver, with a camera on it's helmet.
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Danbury Connecticut
    There's nothing wrong with mounting your camera behind the windshield.
    You may find, however, that you'll get better pictures if you mount your camera as high as possible.
    I had a camera mounted behind the windshield, another one on the left mirror.
    Now I mount my camera to my helmet. I find I get more interesting photos since I can turn my head and photograph views on one side or the other.
    Before that. all my photos seemed to look like a double yellow line.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Idaho
    Quote Originally Posted by ThreeWheels View Post
    When I used my GoPro a few years ago to record some of my rides. I had the camera mounted just above the headlights on a rotating mount so I could catch videos of the scenery along the road. What I ended up with was a majority of the videos showing the boring road straight ahead, or the scenery in the top half of the frame. The lower half of the frame showed a good view of concrete barriers or guardrails.
    The best setup is what Pierre (SpyderTV.net) uses, or what Martin the Vlogger (https://www.martinthevlogger.com/) has. Both are pedestal mounted up high behind the driver. They're up high and can pan the scenery. You'll have to search their stuff to find images showing the mounts.
    2014 Copper RTS
    May 2018
    millsboro,delaware
    Ive got a Sena 10c on my helmet and when the windshield is fully up sometimes the camera is looking thru the shield and there is no problem at all.Even when the shield is a little dirty it still doesnt make much difference.
    : 2017 RTL ORBITAL BLUE
    Aug 2013
    SF Bay Area
    Behind the windshield is just as good as in front.
    "too blurry in rain," It will be too blurry in front of as well as behind the shield.
    "reflected light during night riding," Depends on the camera.
    "contending with bug gizzards obstructing the view," Bugs can hit the camera just as easily as the shindshield.
    "dust buildup behind and in front of the windshield," Whether in front of or behind, dust gets everywhere.
    "Windshield shake affecting the image quality," What shake? My windshield doesn't shake.
    2021 F3 Ltd , Magna Red
    Jan 2019
    Thanks for all the responses.
    I ended up going the same way as EdMat, though my cameras aren't as discreet as his.
    2017 RTL
    2017 RTL , White
