Results 1 to 10 of 10
    Active Member MarkN's Avatar
    Mar 2022
    Mio, Michigan
    Default Anyone ever back-fed their battery maintainer thru a USB port?
    Has any one ever back fed their battery maintainer through a USB port?
    Last edited by Peter Aawen; 02-01-2024 at 03:11 PM. Reason: Expanded title to briefly ask the question... ;-)
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    2021 600 , Black/Yellow
    Aug 2013
    SF Bay Area
    Most battery maintainers come with a pigtail that attaches to the battery. A lot of dealers install one and run it out into the frunk. Makes it easy to plug in with the frunk open.
    2021 F3 Ltd , Magna Red
    Quote Originally Posted by MarkN View Post
    You mean feed the battery from the maintainer through a USB port on the Spyder. That can't be made to work at all. USB is 5 volts and the bike electrical is 12 volts. Plug your maintainer into a USB port and you'll burn up the USB adapter for sure.
    Durham,Maine
    Or the bike!!
    2012 RTL , Pearl
    Feb 2016
    If you've added power ports for heated clothing, you can backfeed the battery charger through them if they're wired (and fused) direct to the battery.
    2020 RT Limited , Marsala Red
    Mar 2022
    Mio, Michigan
    I never thought of any of this. Thank you
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    USB ports supply 5V of electricity with a maximum current of 0.5A. Most trickle chargers are about 15v @ 2A. You're just going to melt the system down if you attempt this. Go with the pigtail that comes with most of these chargers, direct to the battery.
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    FWIW we use the heated gear ASE cable.
    Maybe that will help?
    2021 RT Limited in Marsala Red & chrome (9/20)
    2006 Yamaha Royal Star Venture - Black Cherry
    2003 Suzuki Volusia - Black w/ Gold
    1973 Honda CL350 - Hawaiian Blue
    2021 Limited , MArsala Red & Chrome
    Mar 2022
    NH
    I plug my battery maintainer in the back trunk cigarette lighter outlet...
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    I have a cigarette lighter outlet mounted on my handlebar attachment bolts, wired straight to the battery. And I plug my battery maintainer into that.
    Last edited by Peter Aawen; 02-23-2024 at 05:30 PM. Reason: Fixed attach display ;-)
    2022 Spyder RT Limited Sea to Sky Mystery Blue
