Results 1 to 12 of 12
    Dec 2020
    UT
    Default Clicking gear sounds when accelerating?
    Hi All,
    Holiday greetings from Salt Lake City! I picked up my new 2020 Ryker Rally a couple of weeks ago and now have about 250 miles on it.
    One thing that I've noticed is what I would describe as a clicking gears sound that happens sometimes when accelerating.
    It may be that as is the case with all bikes, just takes some getting used to accelerating smoothly?
    Mentioned it to the sales guy at the dealer and brought it over for a look see. He drove it around for a bit and said there is nothing wrong with it.
    Anyone know of this issue with any other Ryker's?
    Thanks,
    Michael
    Nov 2020
    iowa
    So the sound you are hearing is normal. It will get a little quiter with time, but its the design with the belt. Nothing to worry about.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    A thunk when the centrifugal clutch engages is normal unless the throttle is rolled on very gently. I would associate a clicking sound with something more sharp. Does it happen only when accelerating from a stop?
    Or is it a repetitious sound? If so, what is its frequency, such as one click per second?
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Sep 2019
    illinois
    Have a knowledgeable mechanic check it out, not a salesman.
    Dec 2020
    UT
    Default LOEMichael
    Thanks for the response. Just happens from a stop. Michael
    May 2020
    New Mexico
    If you don't mind taking an extra second leaving a stop, roll the throttle on gently to engagement RPMs and the primary clutch thunk/clunk is less likely to be heard.
    Jul 2020
    Florida
    I dont think its the initial clunk at starting off that he's talking about. I get the same clunk and then several slight clicks at start off, its done it since day one, no performance issues related to it. Seems not to happen if I give it more throttle at take offs, but if I gently give it just enough throttle to engage, I get the clicks.
    2020 Can Am Ryker Rally Sport Touring Edition
    Sep 2017
    Durham,Maine
    There's a lot going on in there you have two clutches in there that operate on centrical force, dogs engaging, rollers, and not to mention parts that slide on each other and those parts do have a little play in them, so you will have some sounds coming from them!! If you have ever had a sled you will hear these sounds quite often. When the sounds are very load and constant that's when it's time to worry! With my sleds I take my clutches apart and clean and inspect for worn parts yearly, you get a lot of belt dust in there that will gum things up and stop them from working right! I will admit I don't own a Ryker, but I am formulary with centrical clutches! Good luck, be safe!!!
    2012 RTL , Pearl
    Dec 2020
    UT
    Thanks!
    Dec 2020
    UT
    Will do. Thanks!
    Dec 2020
    UT
    A thunk is a better description of what I hear, so I'll get the feel of the throttle as time goes on. Thanks!
    Dec 2020
    UT
    All makes sense. Thanks Mikey!
