Results 1 to 25 of 29
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Default Kumho mounted, not balanced yet
    Today I had Vredestein Quatrac 5s mounted and balanced on the front wheel and a Kuhmo Ecsta mounted, but not balanced, on the rear. The local tire shop couldn't balance the rear, because the hub wouldn't fit on their machine.
    Two methods occurred to me: Drop balance the wheel using the axle and weights, or Ride-on. I think Ride-on is the way to go, but 30 minutes of web searches didn't find any car formula Ride-on in stock or available. I need 17oz -- anybody have a lead to some?
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Feb 2019
    Portland, Oregon
    I had problems with Ride-On. It would put the tire out of balance and when I got a puncture, it didn't do its job of plugging the small hole. So I went to Counteract beads - less abrasive than Dyna Beads. The Counteract beads worked very well and don't make a mess inside the tires. Ask tire people what they think of it
    If your rear Kumho has been mounted properly, there's a better'n very good chance that you won't actually need any balancing done on it at all!
    So give it a ryde, run it up & down thru the gears a few times, take a few corners at speed (safely if you will, please! ) and if it's not giving you any grief, then don't buy yourself trouble that's not really there, just get on and Ryde!
    I have probably run more rear tires on my Spyder than just about anyone else here except maybe SpyderAnn & a couple of other 'high mileage' ryders, and I seriously cannot remember the last time I had any concerns re balancing my rear tires Modern tires from reputable manufacturers fitted/mounted properly on their rims & run on the rear of our Spyders/Rykers will rarely need balancing.
    .... I've had 7 rear auto tires on various Spyders .... I only balanced the first one, and discovered it only needed 1/2 oz. .... The next six I didn't balance and have not noticed a vibe or wear issue .... IMHO the way the swing arm is constructed, it provides a stronger more stable fixture for the rear axel / wheel .... No one who has driven my Spyders have ever mentioned they thought something wasn't right about the rear end or said there were any vibes ..... good luck ..... Mike
    Apr 2020
    Edgerton,WI
    Lightbulb
    Quote Originally Posted by ButterSmooth View Post
    I use Centramatic wheel balancers available from LaMonster.... takes all guess work out of the equation. They work!
    2019 F3L , Covid Blue
    Florida Swamp
    I just used the axle on 2 jack stands and taped the weights on until it didn't roll on the rear Kumho. Peeled the paper, stuck the weights on, and it doesn't vibrate enough to notice at any speed. Been on there for about 5,000 miles and showing no wear at all. Still no vibrations. Only used about 1/2 oz of weights. Don't have any beads in the tire.
    2019 F3-S , Black & Silver
    Feb 2020
    N. Wilkesboro, NC
    I went to the Counteract website. All I could find for motorcycles was some sort of innertube (I guess). Is that what you're referring to? Does it go IN the tire or on the back side of it like the Centramatic balancers?
    HAGO!
    Sep 2020
    Central Oregon
    Quote Originally Posted by MONK View Post
    HAGO!
    https://www.amazon.com/gp/product/B0...DX5J7QN2&psc=1
    Spyder Tryke Pylot
    Sep 2020
    Central Oregon
    Quote Originally Posted by Gwolf View Post
    That is my drop balance plan, but if Peter and Mike are to be believed (risky ) I shouldn't have to do anything. My plan at this point is to put it on the drop balance setup, just to see how far it's out of balance. Then I'll put it on the Spyder and if I feel anything, spend the $25 and add Counteract beads. Another worry eliminated.
    Supposed to be 50° tomorrow, so that will be the big new tire test!
    I truly appreciate the help guys!!
    Spyder Tryke Pylot
    Nov 2016
    Upstate NY
    Dont waste your time balancing it. It should be fine. I have installed 3 rear tires without balancing and had no issues at all.
    Aug 2019
    southwest oHIo
    The shop that mounted and balanced (most of) my tires also could not balance the rear. When I got the wheels and tires back to my shop, I used the axle and jackstands method to check the balance on the rear. I could not find any need to add any weights, so I just put it back on the bike. 5200 miles on the Q5s so far, and nothing has changed my opinion that any weight needed to be added.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Quote Originally Posted by Steve W. View Post
    Just so we understand ....No balance weights on the REAR .... but did you have to balance the Q-5's ( the front tires ) .......... Thanks, Mike
    Feb 2019
    Portland, Oregon
    Quality tires do make a difference for the better. My front Kendas had a least 3 ounce of weights on each wheel. Had a pair of Federal Formoza mounted on the front and each got but 3/4 of an ounce to balance.
    Sep 2020
    Central Oregon
    Road force balancing my front Vredesteins resulted in forces of 8# and 10# remaining, which is well below the 20# threshold of perception. I don't know what the max acceptable force is, but the tech thought these tires were quite good.
    Spyder Tryke Pylot
    I'm surprised the tire guy didn't offer to put a liquid tire balance in it. My local tire shop put Liquid Balance in my rear tire, the same stuff they regularly use in large pickup and truck tires.
    Sep 2014
    USA
    Last two rears I put on used Counter act beads , that is it and never had a issue.
    Jul 2011
    Mitchell, Ontario, Canada
    If it was my Spyder I would take off the Kuhmo and put on a better tire. I hate to say it but a crappy Kenda is better then the Kuhmo. As for balancing. Just put in some beads.
    Aug 2019
    southwest oHIo
    That is correct. I just checked, one front wheel required 1/2 ounce, the other required nothing.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Houston
    I recommend taking the tire and wheel to a motorcycle shop that has the correct tools to mount and balance that tire correctly. Do the job right.
    I also agree with the sentiment you can do far better than that Kumho for a tire. Those get rather squirrely in the rain and are pretty poor traction.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Mar 2015
    forrest above Reno, Nv
    +1...........
    2014 RTS , Circuit Yellow
    Active Member mully's Avatar
    Jul 2018
    Harrison, wisconsin
    https://www.ride-onshop.com/Dents_an..._-_Bottle.html If you go with the ride-on balancer/sealer here a link to the dent and ding section that they have instock at a discount.
    2018 F3s, 2016 versys 650LT, 2001 concours 1000
    Sep 2020
    Central Oregon
    Quote Originally Posted by mully View Post
    Yeah, I was there and it look great until the cheapest shipping was twice as much as the product... Thanks, though!
    Spyder Tryke Pylot
    Sep 2009
    La Valle, WI
    I have the kumho ecsta and it only took 1/4 ounce and is a way better tire then the crap kenda that had 3 ounces of weights out of the factory. I have 9k miles on it and still not half worn yet. Crap kenda was bald in the middle at 9k. For OP dont bother balancing it.
    2018 F3 Limited , Oxford Blue
    Aug 2019
    Stoughton, WI
    I ordered (3) bottles of the auto formula awhile back from the scratch/dent. All arrived full/perfect shape. With the USPS Priority option, it was $50. That's about $16.75/bottle mailed. Not sure you can find it any cheaper..
    2022 RT Sea To Sky
    Active Member dicko's Avatar
    Jun 2008
    Ballarat, Vic, Australia
    Most car tyre dealers are willing to fit the 225/50R15 tyre on the rear rim but cannot balance it. After a couple of recommendations to go a motorcycle shop, I did. They cannot do it either. Said they cannot do the big wheeled Harleys either. Bike dealer said owners just don't get their rear wheel balanced. After a discussion with the bike dealer, I suspect that the wheel is balanced in the factory. Apparently it's generally the rim that needs balancing, not the whole thing. Reckoned that a car tyre on the rear would be a lot tougher than the OEM Kenda and not getting the whole tyre/rim balance should not be an issue. I'm guessing when I got a Toyo on my last Spyder there was no balancing done.
    The only directional / symmetric tyre that I can get appears to be a Yokohama AVS ES1000 P225/50R15 91V. The Toyo in that size is no longer available. Can get more choice with a 225/45R15 but I'd prefer the correct size in case the VSS spits the dummy.
    ɹəpunuʍop ɯoɹɟ oʞɔıp
