Results 1 to 7 of 7
    Default Date & Time Stamp Test
    Testing to see what time clock Spyderlovers.com uses.
    Ron (bajaron)
    Apr 2013
    California
    This is Rich from California. Just saying hi !
    Aug 2019
    southwest oHIo
    Any forum I have been on has always shown up as local time, even when I cross the time zone lines.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    May 2018
    Yuma
    Baja Ron @ 11:17 AM makes sense. ncll @ 12:30 PM makes sense. Steve W. @ 01:30 PM doesn't make sense. Military time works well and is real easy to learn. I'm guessing that 01:30 PM would be 1330 military time. No offense meant.
    Quote Originally Posted by YumaGary View Post
    Yes, military time (a 24 hr. clock) is much easier to work with. I was never in the military. But working for the fire department was always on military time. The kind of hours we kept on incidents made it much more clear as to when we needed to be where with no confusion. And 1:30 pm is 1330 military time.
    Server Admin AnthonyG's Avatar
    mi
    I gave you the ability to select your date & time formats.
    https://www.spyderlovers.com/forums/...do=editoptions
    Two new options on the bottom.
    2018 F3 , Red
    mi
    Ron (bajaron)
    Any server should be set for its GMT zone its in.
    Your post date & time is based off what you have set in the usercp here.
    If the thread & posts date & time are off, that means you selected the wrong timezone in your usercp.
    Guests always see the timezone i set in the admin panel, which is the servers GMT zone.
    The server isnt actually using NTP to sync its time, its probably off by a +/- some sec/mins, as i typically dont check it after i install an OS.
    2018 F3 , Red
