Results 1 to 9 of 9
    Sep 2017
    Wa.
    Default Anti freeze puddle under Spyder
    Iv seen couple little bitty puddles under my '17 spyder rt this fall. Thought it was maybe from hitting puddles of water. Well I put the spyder up on stands an went looking after I saw little puddle other day an hadent hit any puddles or had any rain.. Yep for sure found drop of anti freeze ready to drop off from clamp on hose. It was the little hose up above a radiator hose. I see that the hose clamp had been changed . I asume at the dealer during one of the service jobs done there. It was a screw tightning clamp (a regular hose clamp people buy at the auto parts store). I tightened it about one turn, took spyder down an went for a ride an put it back up an no leak. Put couple parts back on Spyder an now its ready to go. Anytime the road doesnt have ice, snow, crap they put down on road to help melt the snow. Ride all winter when roads are clear. I know I should of changed the rest of those crappy hose clamps from the factory to the good ones but didnt have any in my shed. Probly will when I do the next service In the spring. It will be me doing the service's from now on instead of the dealer. Nathan in Yakima,WA.
    Jul 2011
    Mitchell, Ontario, Canada
    I have to disagree with you. The factory Oetiker clamp is superior to gear clamps. Just not home mechanic friendly. Do not replace them unless you need to. Just by your example. You had trouble with the replacement gear clamp and not the OE ones.
    2018 F3 LIMITED
    Sep 2017
    Wa.
    Billy, thank you for your input on the clamps. I will leave the factory one's alone until I have another leak. Hopefully I wont have another leak to fix. Wonder why the dealer didnt tell me they changed the clamp. Have a battery tender now hooked up in the shed to my Spyder to keep it topped off during the cold winter between rides. Thank you, Nathan in Yakima,Wa.
    Aug 2007
    Greeneville, TN
    I would agree with billybovine. The stock clamps are used for ease of assembly. But they are good clamps. The screw clamps usually need to be re-tightened at least once after install, They do not have much ability to maintain the needed pressure as the hose settles in to it's new circumstance. I would check tension again, even if it doesn't leak anymore. when the system is hot. That's the best time to improve the seal on a screw clamp. If you can do it without getting burnt.
    Jul 2014
    Mint Hill, NC
    If you're going to use the OEM clamps, called Oetiker clamps you need a special pair of pliers. You can get them, Knipex 10 99 1220, from Amazon, https://www.amazon.com/10-99-I220-Cl...6253641&sr=8-3.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Quote Originally Posted by ned64 View Post
    They may not have changed it. My 2014 ST came with Oetiker clamps all around *except* the hose coming out of the top of the water pump. That had the worm gear clamp *and* it did leak once or twice early on, especially when the temperature really dropped.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
    Jun 2016
    US new jersey
    question how do you remove these clamps with doing damage to the hose. I have a leak from the overflow bottle .
    Sep 2017
    Wa.
    First clamp I had leak was a screw clamp on from the factory, so a screw driver worked. Now I have had one of the factory clamps leak. I used a thin screw driver. Poked it in an twisted it between the pinched sides of the clamp. Loosened it enough to where I used a bigger flat blade screw driver an twisted it out more. Loosened it enough that I could get a pair of plyers on it an pulled an twisted it till it was loose and pulled the hose off then with clamp still on. Be careful how ever you do it to get the clamp off since the bottle is plastic an you dont want to break it.
    Jun 2016
    US new jersey
    thank you i may have found my issue. after cleaning the bike and going over what could be the issue I removed the cover on top fill bottle and the top was lose,, i am thinking this had to be it....
