SpyderLovers Sponsor
F3 Rear Drive Belt - All Years
I have come by a brand new, never used, never mounted Rear Drive Belt for the F3 Can-Am Spyder. It will fit all year models with an 89 tooth rear sprocket. The other option that came with some F3 models is a 79 tooth rear sprocket. This belt will not work with the 79 tooth version.
$269.00 delivered.
Ron (bajaron)
SOLD!
$269.00 delivered.
Ron (bajaron)
Ron,
is there an easier way to discriminate between the 79 & 89 tooth sprockets???
Al in Kazoo
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
Originally Posted by IGETAROUND
Ron,
is there an easier way to discriminate between the 70 & 89 tooth sprockets???
Al in Kazoo
It's 79 and 89. If you had the 2 side-by-side it would definitely be easier. But counting the teeth on the rear sprocket isn't that difficult. From looking into this, it appears that the S and T models had the 89 tooth rear sprocket. The Std & Ltd had the 79 sprocket up until the 2019 models. Some 2020 & 2021 F3's came with the 89 tooth rear sprocket as well.
Counting the rear sprocket is the best way to be sure this belt will fit. But if you give me your production year and model F3. I will look it up for you.
You are correct, except for the 2016 F3 Limited also had a 89 tooth sprocket.
BRP Part# 705502157
Fits the following F3 Spyders with 89 Tooth rear Sprocket
All F3 Models with an 89 tooth rear sprocket. The other option which came on some F3's is a 79 tooth sprocket. Which this belt will not work with.
Retail is $319.00 + tax and sometimes + shipping.
Reduced to $245.00 delivered. I will ship Internationally with additional shipping cost.
