Hand grips - anyone found longer a/mkt grips for an F3?
Anyone had any luck finding after market grips for 2018 F3? I ordered a set of clam shell grips from Kuryakyn that work on the RT but on the F3 the downshift paddle hits it so they won't work. Any ideas??
Have used the foam grips but I need a longer grip.
If you dont need or have heated grips. Just put regular kuryakyn iso grips on. They are longer than stock.
They hit the shift paddles on the RT also. You still have to modify them to work and the heated grips take longer to warm up. They are longer,I put wooden dowels in mine to support them. When you get the grips put the bottom part on to see how much to remove to clear. Use a dremel cut it down. You can also cut the paddle which I did the first time but I prefer cutting the grip now.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
Cutting or modifying the grip was the only thing I figured would work, just wanted to make sure if someone else had done this. There is a video on youtube about installing these grips but no mention of having to modify them. Thanks for the info!
