Results 1 to 11 of 11
    Active Member Many brands's Avatar
    Aug 2016
    Atwater, California
    Default Whoever designed ------
    Just changed my Air Filter (2016 RT) I removed 7 pieces of plastic , just to get to the Filter. Glad they didn't hide the Gas Cap too. OH - wait a minute. They Did.
    Some of those jobs can be fun when they build the product from the inside out. And when working on them, make sure to put towels over the "caves" so that the dropped part can be recovered. Ask me how I know.
    Sep 2009
    La Valle, WI
    That is one thing i like about the F3 models. Only have to remove service cover lid. 2 seconds. Than the 4 torque screws on the filter lid and there's the filter. The whole job was less than 10 minutes.
    2018 F3 Limited , Oxford Blue
    Jan 2015
    southern WI
    When I do these jobs on my '16 RT, I have all the goodies on hand to do as much maint. as possible at the same time, air, oil, filters, etc....And, since I have the plastics off, I spray things down well with some Simple Green and wash the crud out while I'm in there. Good peace of mind and satisfaction. When you know what you're getting into and what to expect, it makes it far less stressful and satisfying. When I changed the oil on a buddy's 17 RT, I noticed he had one less panel, and my wife's 19 RT was the same way. I believe they call it an acoustic panel (between the outer shell and the motor that needs to come off to access oil filter)
    2016 RTS , Pearl White
    Linden, CA
    Default Committee
    I have long thought that BRP builds their products by committee,
    and on those committiees none of the people have ever had to repair
    or service anything that has an engine or wheels attached.
    I am also sure they have never ridden a motorcycle type vehicle.
    Only my opinion, and you all know about opinions....
    Many Brands ( posting ) is right they love to bury things, a good example is my good old 2008 GS
    good luck replacing the battery, first you remove the left saddle bag, then the saddle bag mount brackets
    raise the seat and then remove the plastic body panels on the left side and if you are lucky you will find
    the battery under the seat on it's side at an angle.... I got tired of going through all that and moved the battery
    up front in the front trunk where it should have been in the first place...
    Northern Kalifornia
    Default I've heard.....
    I've heard that a moose was designed by a committee.
    Linden, CA
    Default Relocating battery
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    you want to change valve cover gaskets
    Aug 2019
    southwest oHIo
    Quote Originally Posted by Many brands View Post
    Sure, it might be a bit aggravating, but look at the big picture. The manual says you change the filter every 19,000 miles. How many miles do you ride per year?
    If this is your first air filter change, the bike is four years old. You get to look forward to doing it again FOUR YEARS LATER.
    So that averages out to what, about 8 minutes a year?
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    A story I heard years ago involved John Deere. They were getting serious about product quality so to design a new combine they assembled a team of engineers, farmers, dealers, and production workers, to do the design. Then they all went down to factory floor to build the prototype. My friend said you should have seen the blue air that resulted when the engineers started to try the build the machine they had just designed!
    Quote Originally Posted by Mazo EMS2 View Post
    MY miles per year have gone down a bit. so I only change the Oil Filter once a year ..... That access panel means a few other pieces have to be removed first .... so I made a 3 inch " access " hole near the filter cap. works great and so far no difference in heat on the outside panel..... I could probably do the same for the Air Filter, but I have K&N so it delays this chore ..... Mike
