Results 1 to 2 of 2
    Active Member RykerRick's Avatar
    Jul 2020
    Florida
    Default Gas Gauge Not Working
    My gas gauge shows full all the time, even on empty. The bars never move, just stuck showing full. Miles to empty works fine and thats what I've been using to determine how low I am on fuel. Anyone have any ideas? I know I can take it to the dealership under warranty, but I would prefer not to do that if I can avoid it.
    2020 Can Am Ryker Rally
    2017 Kawasaki VX-300 Adventure
    Active Member SportsterDoc's Avatar
    May 2020
    Southern Nevada-Northern Arizona
    Assuming the float is not stuck full up:
    If the Ryker sender is low resistance empty and higher resistance full, then the sender may not have adequate ground or the sender lead is disconnected.
    If the Ryker sender is higher resistance on empty and lower resistance full, then likely the sender lead wire is grounded.
    20 Can Am Ryker 900 ACE...02 H-D Sportster 1200S.....72 Yamaha AT2
    14 Honda CB1100 std..........03 H-D Sportster XLH883...70 Honda SL350
    18 Yamaha XT250...............76 Honda CB750F..............70 Honda CL350
    16 Moto Guzzi V7II..............75 Honda CB360...............67 Honda CL160
    17 Yamaha TW200...............70 Yamaha CT...................67 Honda CB160
    12 Triumph Bonneville..........72 Yamaha CT2.................62 Honda CA110
