Results 1 to 7 of 7
    Oct 2020
    Arkansas
    Default fuel cap fix - any way to make the F3 cap easier to latch?
    Is there anyway to make the fuel cap easier to latch on a F3T? Really don't want to spend $190.00 for the keyless one from Lamonster.
    Mar 2013
    Marion, Arkansas
    A light coating of grease on the rubber seal will work or a coating of WD40 seems to help as offers have posted. My 2017 F3 Limited doesn't have a problem latching the gas cap. Only telling what others have done to their gas caps to make them easier to latch. Hope this helps.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Jun 2014
    Schenevus NY
    The only time on mine that it's hard to latch it is if I forget to turn the key to the right while closing it. As long as I turn the key, the cap closes and latches without issue.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by Trbayth View Post
    I had a bitch of a time closing mine until I was told the above. I would add, after turning key to right and the cap drops down, nearly closed, put pressure with your left hand on front of cap, then turn key left to latch it.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Houston
    Lubricate the sliding part of the latch with the bevel on the end.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Feb 2019
    Portland, Oregon
    A hydraulic ram was needed to close mine. So I dismantled it and filed down the top of the latch about 1/16" plus smear some silicone lube on the rubber seal. Works great now.
    If you are going to attempt this, stuff a rag in the hole to prevent bits from falling into the tank. No, it didn't happen to me.
    Jul 2010
    Las Vegas, NV
    Shim it. Get a beer can and tin snips. Remove the cap assembly, shim it with washers you made from the beer can. It will work perfectly. Needs to come up just a touch.
    Joe Meyer
