Results 1 to 12 of 12
    Nov 2020
    Virginia
    Default 2014-21 RT OEM Shock 'take-offs'
    I am in the process of buying and then installing a Baja Ron sway bar and links. I inquired with Baja Ron about shock spring adjusters and their added value. He said they would help BUT suggested I "replace the 2013 shocks with 2014-2021. Many times you can find a good set of take-off OEM shocks where someone has gone to Elkas, etc. You can post on Spyderlovers.com or look on eBay. Spyderlovers will probably give you the best deal, if someone has a set."
    Does anyone have a good set of take off 2014-21 OEM shocks removed during an upgrade?
    Last edited by Peter Aawen; 11-17-2020 at 07:33 PM. Reason: Prefix & Title after move
    2013 RT , White
    Active Member Marcy's Avatar
    Jun 2016
    Leesburg VA
    PM sent.
    2019 F3T , Blue
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by RogDawg View Post
    The 2013 RT has probably the worst set of OEM front shocks of any Can-Am Spyder. And that is saying a lot! You're much better off getting a good take off set as mentioned above and then installing my shock adjusters if you need them. BRP made some significant upgrades to their OEM shocks in 2014. And have made additional improvements in smaller increments since then. They aren't Elka's, of course. But a very good Bang-For-The-Buck improvement for a 2013 RT owner.
    Good Luck RogDawg!
    Jun 2016
    US new jersey
    Hello, if you can wait till March I'll give you my set of OEM shocks off a 15 RT-S with Spring Adjusters already mounted.
    Active Member spydernatic's Avatar
    Aug 2012
    Covington Georgia USA
    I have a set of OEM shocks from my 2017 RTL I replaced them with Fox podium at around 2500 miles. Let me know if you are interested as I see s
    Marcy sent you a pm.
    2017 RT Limited
    2017 RT Limited , White
    Aug 2012
    Jerry I just sent you a PM
    2017 RT Limited
    Jun 2020
    San Antonio, TX
    Got it! Thanks.
    Aug 2012
    Jerry here is the photo I tried to attach to the PM I sent you.
    2017 RT Limited
    Jun 2020
    San Antonio, TX
    PM sent
    Aug 2012
    Hi not sure if you got my last PM anyway box is on its way to via Fedex
    2017 RT Limited
    Jun 2020
    San Antonio, TX
    Sent you a PM....FedEx claims only the label was created and they do not have possession of the package. You may want to check with them and see.
    Active Member Sampi1099's Avatar
    May 2020
    Apache Junction Az
    Good Luck RogDawg!
    Ron would that be true for the 2012 shocks on my Rt?
