Results 1 to 9 of 9
    May 2019
    Mt. Juliet, TN
    Default Rear Suspension (adjustable via Schrader valve) 2020 F3-T Losing Air Pressure
    Anyone else experiencing the loss of air pressure in just a short period of time?
    I can set the pressure @ 30 psi and enjoy the ride that day. Within 2-3 days the pressure is lost totally, down to zero psi. Is this normal? Still under warranty so should I have it checked? Just not sure if this is by design or I have pressure loss because of a failing seal or something??
    That's a little quick, so given that you've still got warranty, you should probably get it checked!
    Aug 2020
    Georgia
    If I set my 2020 base RT to about 53 it will lose about 1 psi per day for a few days but then when it gets to around 46, its rate of loss slows down dramatically. It has never dropped to zero - I think it would take 2-3 weeks of no riding for that to happen.
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    As a blind/easy/cheap fix ATTEMPT, change out the schrader valve core. They frequently fail and leak. Worth a shot since we get lucky sometimes.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Feb 2020
    N. Wilkesboro, NC
    I recently spoke w/someone who has a 2016 F3T who said his rear suspension leaks. My 2021 RT does not. Well, I'll lose a pound or 2 in a week but that's easy to fix.
    Mar 2017
    Even if your schrader core is bad and replacing it might help, if you put a good cap on it with an oring inside it to seal it, it should not lose air that quickly.
    Mine will lose about a pound a week. I have permanently added a 12v pump to my left bag using some tire valve extensions and added a 12v power outlet there as well. More details and links at my page in my signature.
    Aug 2020
    Georgia
    I put in an extension on mine so that it is easier to access. I check it before every ride. If I do any overnighters (hopefully lots once this COVID issue is muted) I will prolly buy a small pump ($) and keep it on the bike or replace the shock with an aftermarket ($$$).
    Feb 2020
    N. Wilkesboro, NC
    I added an extension to the Schrader valve on my 2021 RT (base) but I think you guys are overthinking things. If it leaks a LOT, take it to the dealer as it shouldn't. If it just leaks down a pound or two in a week, buy one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 . That's what I've got and I check the pressure as part of my pre flight checks. If it's down a couple pounds, it literally takes 90 seconds to screw on the pump, give it a couple "squirts", unscrew it and stow it away again the saddlebag/frunk.
    Mar 2017
    Quote Originally Posted by MONK View Post
    I wouldn't class it as overthink. I'm out of warranty. My solution using a small $22 pump shows immediate reading of current pressure & just a switch if it gets low or I'm having a passenger. Beyond that if I need it, my pump will fill a tire as well.
    Full details can be found
    to see full details on MY SPYDER PAGE
