Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Lots of things effect that. Load weight, spring rates to name two. We adjust to 3/4 to 1 1/4 toe in measured at 120" between targets. Which end of that range we shoot for depends on load and spring rate.
    So that would be -.5°±.12°. BMW specifies that wheel alignment be done with the driver in his seat and 200# sandbag in the passenger seat, much like your "load and spring rate" adjustment range. I like it!
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
  2. #27
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    wouldn't 3/4 inch of toe-in cause front tires to scuff outside edges pretty badly?? ..... and 1 1/4 inch toe-in would seem to slow you down and really scuff the tires.(??)
  3. #28
    Jul 2019
    UK
    Quote Originally Posted by redrazor View Post
    Yep, I agree. That's seriously wrong.
    Using the wheel rim as the datum (not the tyre) 2.5 - 3mm toe in is a good starting point. That's less than 1/8" for you USofA folks.
    Rule#2: Never argue with an idiot. He'll drag you down to his level & then beat you with experience.
    Rule#1: Refer to rule #2.
  4. #29
    Jun 2019
    Kansas
    Perfect! Thanks for digging.
  5. #30
    Very Active Member Cobwebs's Avatar
    Sep 2018
    Australia
    Quote Originally Posted by PinkRosePetal View Post
    Divide those numbers by ten is how you arrive at the actual toe in. The laser targets are spaced out ten foot apart to give accuracy.
    2017 F3S Daytona , Circuit Yellow Metalic
  6. #31
    Idaho
    Note that JC said 120" between targets. That would the toe-in over 120" which most likely is the targets spaced 60" in front and 60" behind the wheel center. That's about 0.6° for 1.25" toe-in.
    2014 Copper RTS
  7. #32
    Sep 2013
    Houston
    deleted
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  8. #33
    Jul 2019
    UK
    You did not read what I wrote. Toe in is set at 3/4 to 1 1/4 toe in MEASURED OVER A 120" TARGET DISTANCE.
    That's not my quote but yep, I just clocked that, I obviously had my squint thinking cap on, apologies to you, JC.
