3.5" Rox Risers on a 2020 RT?
Has anyone tried the 3.5" Rox Risers on a 2020 RT? Is there enough cable to use these?
Not sure about the 3.5" ones, but 2" ones should work. You should get these .. https://roxspeedfx.com/collections/a...ant=1187894173 as they have the extended stem. Also, to allow better fore/aft movement, buy a top clamp for a F3 .. Black Central Handle Clamp
709401904
$16.99
https://www.partshark.com/oemparts/a...26a3e/steering
2022 RT Sea To Sky
Originally Posted by troop
Yes, I've already got the F3 top cap.
And ... If you have a 12V/USB Powerport set up on top of your handlebar clamp, the risers will not work. That was my experience...
2022 RT Sea To Sky
