Results 1 to 9 of 9
    Feb 2012
    Spring City,Utah
    Default R&R regulator/rectifier and Stator
    Rode my 2012 RTL VTwin 375 miles there and back for a Patriot Guard mission Friday. On the way home the charging system gave out and I rode about 125 miles on the battery. So now I am looking at replacing the RR and the stator. I have watched Smoaks video on that and it seems fairly straight forward. Anybody else done this? Is there anything he didn't cover? Any tricks? Also I couldn't find the stator on cheap cycle parts. Anybody have the part #. Or which fiche it is in? TIA. Spyder currently has almost 63,000 miles.
    Last edited by ARtraveler; 11-09-2020 at 10:46 AM. Reason: spell/charring to charging
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2020
    Platte City, MO
    I pulled it up in Peggy's service manual for her 2013 STS-SM5, and it shows the part number "420685500 Stator Plate". Also shows the cost
    at $411.49.
    PartsPitstop.com shows it here: https://www.brppartspitstop.com/oemp...ectric-starter
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    In the BRP Roadster parts catalog go to fiche 03- Magneto and Electric Starter. The Stator Plate is Item 8 in the fiche, PN 420685500, $441.99 and is available. CCP lists it in the same fiche by title at same price.
    Rode my 2012 RTL VTwin 375 miles there and back for a Patriot Guard mission Friday. On the way home the charging system gave out and I rode about 125 miles on the battery. So now I am looking at replacing the RR and the stator. I have watched Smoaks video on that and it seems fairly straight forward. Anybody else done this? Is there anything he didn't cover? Any tricks? Also I couldn't find the stator on cheap cycle parts. Anybody have the part #. Or which fiche it is in? TIO. Spyder currently has almost 63,000 miles.
    I would make really sure the " stator " has Failed. .... either eliminate all other causes and/or test the Stator......jmho .... Mike
    Feb 2012
    Spring City,Utah
    Thank you all for your responses. Wow they are pretty proud of that stator. Mike it has been my experience that when one goes it takes the other with it. I will be testing them both but don't hold out much hope.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Nov 2015
    Chardon, OH
    I trust you've checked the fuse?
    Doug
    ”Freedom is not a loophole”
    Feb 2012
    Spring City,Utah
    Actually Doug (he said with a sheepish look on his face) no I didn't. Thank you for the reminder.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Active Member SpyderJerry's Avatar
    Aug 2017
    Deerfield, Wi
    Here is a reputable company to have your stator rewound. Have used him for some years. Does not look like he has units built in stock. But you can check with him at this site. But do make sure you test the stator firs, very good procedure in manual.
    https://www.facebook.com/RicksMotorsportElectricsInc/
    2014 RT SE6
    Feb 2012
    Spring City,Utah
    Thanks Jerry that's good info for all of us. Maybe he can also make it a little more powerful too. I'll ask.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
