Page 1 of 2 12 LastLast
Results 1 to 25 of 37
    Aug 2020
    St Louis Missouri
    Default What Flat Tire Prevention Product??
    While browsing the web, I ran across a produce called "Ride-On Flat Tire Sealer and Balancer". www.ride-on.com
    Has anyone had any experience with this product?
    Or does everyone just plug or get towed?
    I am just curious and thinking ahead.
    Member Jomarfl's Avatar
    Jul 2019
    Zephyrhills, Florida
    Personally, I carry a plug kit. If that didn't work I would get a tow. From what I hear, and I'm no expert, either the tire sealer usually ruins the inside or most places don't want to mess with the goop. Tires for the Ryker are fairly cheap, better to buy a new tire than mess with goop. Again, no expert, just my opinion.
    Active Member Greven's Avatar
    Oct 2019
    Sweden
    I have a can with goop with me for emergencies, to temporarily fix and inflate the tire
    But I've heard the same as Jomarfl. The tire shop will not be too amused having to clean up the goop! Then on the other hand, getting a tow truck is quite expensive, so even if the tire shop charges you extra due to the goop it may be cheaper. Just something to consider
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Quote Originally Posted by BobCat01 View Post
    Plug kit and CAA member. (like AAA)
    I’ll try a plug if it’s a hole in the tread area. If that won’t do it I’ll call for recovery.
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Apr 2019
    Clinton, MS
    If I can't plug it using multiple plugs then goop ain't gonna seal it off either.
    Sep 2017
    INDIANA, USA
    Default Tire Repair
    No Goop for me. Most tire shops will not repair the 'Goop' tire. Like others have said, plug it or call the recovery people.........
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2019
    Stoughton, WI
    I've been using Ride-On sealant in my motorcycle tires for years. Knock on wood .. haven't had any flats to test it, but magazine reviews praise it. Works great as a tire balancer and doesn't leave a mess come tire replacement time. However, I do carry a plug kit/mini compressor when I travel on long, out of state trips.
    2022 RT Sea To Sky
    Aug 2007
    Greeneville, TN
    I use Ride-On. It works very well for me. I use the car tire version (though Ride-On originally recommended the Car Tire version for the Spyder, they switched, for some unknown reason, and now recommend the Motorcycle Tire version. But since the Spyder & Ryker use car tires, it doesn't make sense to me.). I've used both versions in the Spyder and Ryker and I prefer the car tire version better.
    Ride-On stays on the inside of the tread area. It really isn't messy like Slime or similar sealers. Some have complained that it didn't seal well. But if you get a hole anywhere other than the tread area, it won't seal. And you usually can't fix a sidewall leak with any reliable patch anyway.
    Ride-On also helps to dynamically balance the tire/wheel. Overall, I have been very pleased with Ride-On. The only drawback that I've found is that if you let it sit for a few weeks, it will take a few miles of riding to redistribute it inside the tire. You'll get some out of balance for those first few miles.
    Aug 2008
    MA & NH
    Plug kit.
    Oct 2016
    Sebring, FL
    What BajaRon in post #8, I've used RideOn for years and it worked for me. The new formulation is light years ahead of the old formula, no rim damage, no environmental damage, washes away with water.
    You can go to their website and read for yourself the declarations and claims. I'm sure there are some YouTube demo's out there too.
    Jul 2020
    Florida
    I also carry a tire plug kit (different plug diameters) & portable compressor. The three different times I've had to plug a tire on the road, its never let me down.
    2020 Can Am Ryker Rally Sport Touring Edition
    Aug 2007
    Greeneville, TN
    Plug kits are fine. But I had a plug come out of my rear tire on my Suzuki M109R on the freeway (75 mph). It was all I could do to get over onto the right shoulder from the left lane. That tire flopped from the right side of the rim to the left side. To stay upright I had to steer to match or go down. Fortunately, there wasn't much traffic and I did not go into the left side guardrail. With Ride-On, I would have avoided all of that. There are pluses and minuses to any choice.
    Granted, a flat on a Spyder isn't nearly as dangerous as one on 2 wheels. Still, no flat is better than plugging a flat tire.
    Bossier LoUiSiAna
    No one else mentioned yet so:
    http://www.lamonstergarage.com/tire-sealant-4/
    &AMA roadside has more than paid for itself on 2 or 3 wheels
    https://americanmotorcyclist.com/
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Oct 2020
    las vegas
    How does ams roadside work? Any people who have used?
    Jan 2009
    austria
    I had a flat on the front - repaired it and still OK .. after 7.000 miles or so !
    https://www.spyderlovers.com/forums/...ight=flat+tire
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Check out Dynaplug, as cheap as $21.95, with free shipping direct from Dynaplug.
    http://www.dynaplug.com/carbon.html
    As for inflation, I have a super compact German made footpump, which will inflate a P/U tire in reasonable time. Carried it on last 4 M/C.
    Not had a M/C puncture since 70s, but prefer to be prepared for solo rides in remote areas out of cell service.
    Without a plug kit, I would be walking along the shoulder, looking for a screw to insert in a puncture to get me home.
    Some riders are satisfied with a cell phone and credit card, but many of my rides have limited cell service.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    western Colorado
    I use it in both spyder and Subaru Forester. Like having the extra flat protection. As other said if tires sit for a while you will notice out of balance for a short period
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by happyspyder2039 View Post
    And in cooler weather, until tire warms up.
    2022 RT Sea To Sky
    May 2020
    New Mexico
    Like driving on Nylon tires of yesteryear?
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by SportsterDoc View Post
    Ha .. not that bad. The liquid just takes a bit longer to warm up to distribute. Might get a bit of h-bar shake for a few miles
    2022 RT Sea To Sky
    Aug 2020
    St Louis Missouri
    I received an email from Ride-On.com. And even though ryker, spiders, and slingshots have auto type tires, they only advise using the motorcycle formulation for these vehicles. So that is their advice.
    Aug 2019
    Stoughton, WI
    I used the automotive type in my Spyder, as I am literally running car tires. I would not hesitate to use the auto formula in the OEM Kenda tires. I bought my Ride-On directly thru Ride-On in their dented/leaking bottle section. All arrived in perfect shape.
    2022 RT Sea To Sky
    Oct 2016
    Sebring, FL
    Troop, thanks for that tip on dented section, didn't know Ride-On had one, I'll be checking that out. Was it difficult loading into the rear tire? That sucker is difficult to even do an air check.
    western Colorado
    The bottle comes with hose that slides on valse stem. Only hard part is letting air out and squeezing bottles of goo thru vale stem. For me the bottles would get air and suck the stuff back out every now n then.
    Aug 2019
    Stoughton, WI
    1.) Lift the tires up off the ground and then let the air out. Remember to remove the schrader valve.
    2.) Warm up the Ride-On under hot water to help loosen it up. Makes it much easier to squeeze into the tire.
    3.) I always shake the liquid to the bottom of the bottle after each squeeze. Keep the tube on the valve and simply pull off the bottle. It might take quite a few squeezes.
    2022 RT Sea To Sky
