Results 1 to 9 of 9
    Active Member Outporter's Avatar
    Nov 2011
    Bay Roberts, NL, Canada
    Default BRP Connect & Sygic GPSNavigation
    I've notice that the BRP Website has removed "Sygic" and added "Sygic GPS Navigation" in the list of compatible apps., not sure when the change was done. Also the BRP Connect app itself list "Sygic GPS Navigation" as a [New] app but still shows the "Sygic" app. as well. Does anyone have any experience with BRP Connect and "Sygic GPS Navigation"?
    Cape Spear, NF. Most
    easterly point in North
    America
    Provinces & States visited on
    Motorcycle
    2 and/or 3 wheel
    Sygic GPS Navigation is an updated and renamed version of Sygic.
    Nov 2018
    St Pete Beach
    Quote Originally Posted by Outporter View Post
    Does your BRP App on phone show the Sygic GPS Navigation" app? Think you say it DOES. If so, iPhone or Android, my droid only shows the old Sygic.
    Sygic has been making various versions, the car connected we've had, the GPS Navigation you mention, and a Truck version with a few extra features. The GPS Navigation version is worlds better than the car from playing with it on my phone, much more modern etc. Very hopeful they are migrating that version to BRP Connect. Thanks
    2018 RT , Asphalt Grey
    Nov 2011
    Yes, it does show "Sygic GPS Navigation" in the list of apps in BRP Connect with the [New] tag. However when you download and open "Sygic GPS Navigation" it puts it in the loaded apps [greyed out] and removes it from the "More apps" list, so if you download it and only check the more apps list you won't see it but it is there in the loaded apps. This is on iPhone.
    America
    Motorcycle
    2 and/or 3 wheel
    Nov 2018
    St Pete Beach
    Thanks. Not yet on Android. Hopefully that means it is coming to replace the Car Connetced version you can no longer get. Much nicer feel on the GPS Navigation version. At least I have the old one.
    Aug 2013
    SF Bay Area
    I'm not sure how BRP C works as I still have version 2.12 which happened 8 months ago but I see both Sygic GPS as well as FOBO ii up in the top to be installed. Will check out to see if they work. I also need to see if the dash locks up like it did. I also need to see if Rever works. If they all do then I might start using it again.
    I checked it on the bike and found the two new app work. Rever open in the phone but the phone doesn't go dark which means the BRP app doesn't come back as the up front app and the dash can't open it. So I think there is a dash update coming if not already out. Haven't checked Cardo yet.
    2021 F3 Ltd , Magna Red
    Aug 2013
    SF Bay Area
    Just tried it out and there are still glitches. Slow to start and have to be stopped to get music playing. If you use BT music then you have to go into the menu to switch to bluetooth. I found the Sygic GPS Nav app to want a Car Connectivity fee but when I tried again it worked fine. Any route you have planned had better be saved or you'll have to start from scratch when in the dash. FOBO ii works fine. Rever causes a problem where the app opens and BRP C doesn't go dark again and the bike's dash can't open it. So Rever needs work.
    I will use the Data blocker in the cable and have the phone mounted to the dash. Must faster and it all works.
    Apr 2021
    QLD
    SYGIC doesnt even have my state Queensland on its map of Australia..I can't work BRP connect out at all. Means I'm buying a 2017 RT LTD to avoid it.
    Last edited by Peter Aawen; 05-01-2021 at 01:31 AM. Reason: buyimhna - buying a ;-)
    Aug 2013
    SF Bay Area
    Genius Maps is more stable and is what's been used since the beginning. The BRP C app has had an update and new apps for the snowmobiles and Jet Skis.
