Results 1 to 6 of 6
    Nov 2019
    Kansas
    Default 2016 F3-T saddlebag break.. Am I going to be forced to replace it?
    So the part that clips from the door to the saddlebag broke. I will attach a pic. It is blurry, but you will be able to see the issue clearly enough.
    Not sure how this could get fixed, and am thinking I am going to be forced to replace the door at least..Better question is can I replace just the door?
    What do you guys think?
    Jul 2014
    Mint Hill, NC
    Am not familiar with your model but that broken part looks like it is attached to a liner part, probably with a single screw. I don't find the parts fiche for the bag to be too helpful. Perhaps a dealership parts guy can help precisely identify. Also if you could add another picture of the whole inside of the door it might help.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member ChicagoSpyder's Avatar
    Apr 2019
    Chicago
    Quote Originally Posted by acdcking12 View Post
    It looks there is enough plastic left where you could fab a piece of metal that you can attach to the broken tab with a small screw and some epoxy.
    I would think that you could just order the door from BuRP if my solution fails.
    2018 F3 Limited , Black/Chrome
    Mar 2013
    Yes you can purchase just the door, but it's expensive. I looked at my wife's 2018 F3l and I see one of her latches is chewed up. For the $300+ for a replacement door I will see if I can fabricate something out of aluminum first (if,or when her's breaks.
    Not sure which side, or color you need, but here's what I found.
    https://www.cheapcycleparts.com/oemp...th-black-satin
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2019
    Kansas
    I had a friend come over and he used JB Weld with a washer. Works great. Works better than the original.
    Nov 2020
    Ohio
    ...used JB Weld with a washer. Works great. Works better than the original.
    I haven’t snapped/busted anything on my Spyder yet (“...give it time” methinks)
    But something tells me I should pick this up, and experiment (on something around the house),
    so I’m ready when the dreaded day comes.
    Used some epoxy with much success a few years ago (busted appliances),
    just completely forgot until you mentioned that
    how darn well that stuff works.
    Thanks acdcking12!
    2019 SpYder F3-T
    +Lamonster Mirror Locks AMEN! | +Lamonster FogLights | +MadStad Windsheild | +Dual A-Arm Running Lights
    +Spyclops LED Light | +SpyderExtras Grille | +TricLED Wide-VU Mirrors
    ...and what dreams may come
