belt tensioner position, top or bottom
I am looking to build a belt tensioner for my RS. I have and extensive shop.
I have trawled though all forums.learnt a little bit. Tensioner position never mentioned.
I am wondering if having the tensioner mounted on the top run of the belt, the drive or tension side, is the best place for it. Surely the slack? in the belt would be in the bottom run?. Being the place to apply the tensioner?
Your thoughts please people.
thanks Paul
I don't know anything about the RSs but the tensioner runs on the top of the belt on the RTs. Not sure how much engineering goes into a belt tensioner to determine the correct amount of leverage but I think I'd just buy one from one of our forum sponsors as they've probably done their homework.
Tensioner is a misnomer. It is actually a harmonic dampener. That is the reason it runs on the top of the belt, as that is where you are most likely to get the resonance. All of the solutions out there have the roller running on top.
thanks Paul
IMHO, due to more than a few product failures, as reported on this forum ( which is likely to ruin the drive belt ). I won't use one - Period .... I lowered my belt tension to 160 lbs ( measured wheel on the ground ) and I no longer feel any Vibes at any speeds ..... good luck .... Mike
I've had a bottom one and top one. Top works better. I think a solid idler pully would work better like you see on automotive drive fan belts. With large heavy duty bearings. One on top and bottom. That would act as if the belt was half the size. Bet there wouldn't be any vibs at all.
I've had top and bottom. I prefer top. Instead of using the small roller and bearing which by design rotate at very high rpm. I am using a timing belt pulley from a Hyundai Sonoma. It is 2" diameter with a very high quality bearing. It's been working well for several years.
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
Member: American Legion
Picture. Part number. Also does it fit the brp tensioner arm.
I don't have a part number. It is a timing belt pulley from a 2005 Hyundai Santa Fe. Do not confuse with the serpentine belt idler pulley.
1998 Honda Valkyrie
US Navy Veteran
It looks like you have doc Humphreys tension arm on there?
Yes, I do. The roller and bearing now turn at half the speed as the original. The larger diameter, smooth roller doesn't whine as it rolls over the ribs on the old style belts.
1998 Honda Valkyrie
US Navy Veteran
I won't use one - Period .... lowered my belt tension to 160 lbs ( measured wheel on the ground ) no longer feel any Vibes at any speeds
Same here !
I sure wish you could come up with the part number or where it could be purchased.
Asphalt Grey
Lamonster RT phone mount
Sena SMH-10
Lamonster Belt Tensioner w/ larger roller
Spyderpops Missing Belt Guard
Garmin's GPS
I have been researching this and this is what I think. E-bay Pulley Idler FEBEST 1288-H1 OEM SMD 156604
Part # for what? Sometimes it really does help to quote the pertinent part of the post you are replying to!
Grandpot's post. Part # of the 2" diameter pulley from a Hyundai Sonoma.
Asphalt Grey
Sena SMH-10
Garmin's GPS
I did check Ebay and the roller looks like it might work.
Asphalt Grey
Sena SMH-10
Garmin's GPS
Go to an autoparts store and tell them you want a timing belt tension pulley for a 2005 Hyundai Sant Fe with a 2.7L engine. You don't need a part number.
1998 Honda Valkyrie
US Navy Veteran
