Results 1 to 8 of 8
    Active Member BearX16's Avatar
    Jun 2019
    East Central IL
    Default 2014 RT S Dash Panel - replacing the gauge holes with...??
    This winter I will be removing the dash panel to have it hydro-dipped. My intend is to replace the fuel gauge with a usb port. Will I be able to leave the right side blank, using a 52mm plug, or do I need to have some kind of device there to make everything work? If so I am looking for suggestions on what to install as I have not found, yet, anything I like. I know the gauges both have to be there to work.
    Fred
    As long as you remove both gauges that's all you have to do to make the fuel and temp digital gauges work. You can use a 52 mm blank in the spot you don't want to fill. That's why I haven't removed the analog ones; don't know what I'd want to replace them with.
    Jun 2019
    East Central IL
    I'll be putting in a usb port, as I use my phone to stream music and also as gps. If I'm using both battery runs out rather quickly. Thanks for your input.
    Aug 2019
    southwest oHIo
    It is my understanding that if you remove one gauge, the other one still works.
    If you remove BOTH gauges, they will be replaced by digital versions in the main cluster.
    What would make that a bit "interesting" would be if you wanted to put your charging ports on the left, where the fuel gauge is. When you remove the fuel gauge, you will obviously lose its function, and until you also remove the water temp gauge, you won't know how much fuel is in the tank.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Feb 2017
    We replaced the analog gauges on both our RTs with a dual USB port on the left side and a digital voltmeter on the right side. There is a detailed video in the "How To" section that very clearly explains how the change is accomplished. We followed the instructions and everything worked as expected.
    Quote Originally Posted by BearX16 View Post
    Fred
    I have a 14 RT ( basic ) ... I didn't have those gauges so mine was a bit easier ... I used a couple of small metal tops from two small glass jars ... I added two 12v. receptacles .... When I painted " Deanna777's " dash " Cognac " I removed Her gauges .... What I learned was BRP doesn't give you much wire or room to work with ... If you have angled needle nose pliers it will be much easier ( straight ones will work also ) ..... good luck .... Mike
    Mar 2019
    NEBRASKA
    If you want USB this is sooo easy and u can keep ur gauges. Pierre has a video but I like the red light and voltmeter -
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Feb 2016
    Iowa
    When I disconnected my gauges, I installed a round base RAM mount on one side securing it using the bracket that held the gauge in place. On the other side I bought the proper hole blank from my Spyder dealer for about $7. Drilled the blank so I could install a flip-up voltmeter with a USB port to power my phone.20201029_192503.jpg
    2017 RT Limited , White
