Results 1 to 12 of 12
    Jan 2019
    Hunter Valley NSW Australia
    Default 1 of those recurring BRP Issues RTL Front Srocket
    Just an fyi that my 2017 RTL had its front sprocket replaced about 18 months ago under warranty. A check last week has found the replacement is now doing the same - producing the red dust, luckily my '17 RTL is still under warranty.
    This is precisely the sort of thing BRP need a kick in the nuts for.
    2017 RTL
    2017 RTL , White
    Sep 2020
    Platte City, MO
    By "doing the same thing" you mean it's loose on the shaft splines again?
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Mar 2015
    forrest above Reno, Nv
    Thumbs down BRP failure.
    The front sprocket very recently FAILED on a friends F-3. On top of that she was truly hosed by the only dealer in town for over $600 to do an hour or less work. BRP really has dropped the ball on this one.
    2014 RTS , Circuit Yellow
    Jan 2019
    Quote Originally Posted by Possible View Post
    Thanks Peggy/Howard, have updated my post to describe the issue better - doing too many things at once
    2017 RTL
    2017 RTL , White
    Sep 2020
    Platte City, MO
    From the description, it sounds as though they neglected to lube up the splines before assembly. Fie on them.
    Peggy and Howard
    Sep 2013
    Houston
    BRP has been covering these even on bikes past the warranty date. Usually only for original owners though as a goodwill gesture.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Dec 2018
    ON
    Is there a brp recommended maintenance procedure to prevent the sprocket failure?
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by rwill2cruz View Post
    I initiated my own procedure and so should anyone who knows which end of the wrench to hold.
    Keep a front pulley bolt on hand and periodically (you determine what that is) R&R the front pulley, clean both splines, apply a thin layer of moly paste - not moly lube.
    With but 5K on my F3L, I did that and found that BRP had applied a very small amount of a white grease
    that didn't appear to be moly paste, which is dark.
    Even though this is covered by warranty, I don't want my Spyder parked in some dealer's shop while awaiting the arrival of parts. Then having some Wrench Ape screw it up.
    Jun 2011
    Near Lexington, NC
    How do you hold the sprocket to keep it from turning while removing/replacing the bolt? I recall seeing the paste listed in another thread; will look that up and get a tube. My F3 is coming up on 5k shortly so this will be a good project for the winter.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by ulflyer View Post
    Keeping the tensioned belt installed with parking brake on, loosen the bolt.
    Remove tension on belt.......remove pulley.
    Reverse procedure for install....torque bolt when enough belt tension will hold pulley. Properly tension and align belt per shop manual.
    2019 F3L , Covid Blue
    Feb 2019
    Portland, Oregon
    Per the above, but add; After the bolt is removed, raise the rear wheel off the floor and while rotating the wheel, walk the belt off of the rear sprocket. Reverse to install the belt.
    Dec 2018
    ON
    Removed my sprocket today. No red powder or dust visible before removing. Very little paste on the splines. There was slight rust on both surfaces however no signs of fretting or looseness. This is at 16000km. Caught just in time I think. I ordered Loctite 51048 to reassemble.
