SpyderLovers Sponsor
Originally Posted by JP58
Ron it is a 2019 RT se6.
Definitely off my game today! Thank you for the correction. Even less likely that the oil was the problem as the SE6 clutch is much more forgiving than the SE5. Sounds like a component failure is more likely going to be the culpret.
Today it started slipping in 5th gear on almost any hill.... flat ground with hardly any load on the clutches it was fine.
But I need to get this figured out before we start towing our Freedom trailer we just bought because that will destroy it for sure.
Anyway.... It Will be a few weeks before the dealer can get it in to look at it but I'll be sure to let you guy's know what they found out....
2019 Phoenix Orange RTL
LED head lights, LED fog lights, Lidlocks, Brake light kit, Sway Bar, J&S Jack, Cat Delete, Akrapovic silencer, Idler pulley Kit, Gold Drain Plugs, Magic Mirrors, Bumpskid, Tires, Centermatic balancers, Wick-it Stage 1 tune, Convex mirrors, EBC Brake Pads, EBC brake Rotors, Speed Bleeders, M-2 Custom Shocks, Odyssey Battery, Tinted Windshield, Windshield Arm, Gps Ultimate Seat, Dual air Horns, Modesta BC05 Ceramic Coating, Redline 10w40 motorcycle oil, BRP Passenger arm rest, BRP hitch, Syderpop rock guard 2015 Freedom Trailer
If it were mine, I wouldn't ride it anymore until it's fixed.
Peggy and Howard
Hers: 2013 Spyder ST-S SM5
I just got back from my first 70 mile ride with new Lamonster oil in my 2018 F3L. It ran great. Shifted smoother than with brp oil. No problem with his oil. I think something is broken in your clutch. Probably a spring or something that keeps pressure on the plates. Is there another dealer near you that can look at it sooner. Glad I have 3 can am dealers within 40 miles from me.
The dealer we went to today was about 140 miles away.... went there because we bought a 2015 Freedom trailer from them a few weeks back. While we're there to pick the trailer up, they can look at the tranny/clutches at the same time.
If I had to guess it's going to be a while before we get it back....
JP58,
Thanks for letting me know how you made out with the new oil in your engine!.... I see your from WI.
We took the bike in for repairs today to Twobrothers powersports in Onalaska WI.
Pw. A friend and I went to Spyder Spin event that Two brothers powersports puts on every year at the end of May. It's a small event. I think 50 spyder riders showed up for the Saturday ride.
Maybe we'll go on that ride...that would be fun! Just hope our Spyder is ready by then. I just have a gut feeling this is going to be a long fix, but I could be wrong.
That's another reason we decided to take it up there already....trying to get it fixed before riding season starts in full
Well a LITTLE update.... The dealer did have time today to install the hitch for our freedom trailer and did find the drive belt loose. I told him that's not the "slipping" problem I'm experiencing....no way! He did say he wanted to check the front pully also.... Not sure why. He also said they did have a 4 year spyder in one time that they had to replace the tranny in...but for the most part there bullet proof.
Anyhow we just got snow yesterday so he waiting for better weather to take a test ride to see what I'm talking about. I'll keep you guy's in the loop as to what is going on with the slipping.
P.W.
Front pullys have gone bad. They get the red metal rust dust. When the splines wear out enough the pully slips on the shaft. It could be that. Do a search on spyder lovers. Red dust or front pully slipping. Hundreds of pages to read.
Will do. With 8,300 miles on the bike...could the front pully "splines" be bad already?
P.W.
Absolutely! Lamonster uses a true synthetic oil. Not a mineral oil with an additive package like 99% of the 'Synthetic' lubricants out there. No one should get the idea that this clutch slipping issue has anything to do with Lamonster oil. There is definitely something else a-foot here. Sounds like we could be finding out the 'Why' very soon. Could very well be a front sprocket failure. Could also explain why the belt tension was loose. The plot thickens! (even if the oil does not). ;-)
P.W.
Yes some have failed with less than 5,000 miles. Mostly on F3 models. But RT models have failed to.
I'm not saying this is not my slipping issue..... and the front pully might be bad and could be the problem. But, if the splines in the pully were stripped out, or close to it. I would think it would be slipping ALL the time.......but I did "baby" it to the dealer and backed off the throttle asap when I heard the RMP rise.
Looks like I'll find out in the next week or so if that's the problem..... I kind of hope it is instead of ripping into the clutch packs in the tranny.
Thanks for your time and help!
P.W.
P.W.
Just speculation. We could all be wrong. Could be something out of left field that no one thought of. Not sure why it's always left field. Why not center or right? Another question that will never get answered, I fear.
One way or the other. We will get educated on this one.
I'm going to call them 1st thing in the AM and see if they can look at the front sprocket for me (us) asap.....like tomorrow.
Maybe they won't need to wait for the snow to melt and the roads to get better to get this figured out after all .... and I'll get "Skeeter" back home sooner than I thought.
Thanks to all for your input!
P.W.
Maybe they won't need to wait for the snow to melt and the roads to get better to get this figured out after all .... and I'll get "Skeeter" back home sooner them I thought.
P.W.
The front pulley fix could easily be your best hope. Depending on how it went. The pulley splines are softer than the output shaft they run on. Designed this way to sacrifice the relatively inexpensive and easy to replace pulley while protecting the more expensive and much harder to replace output shaft. Let's hope for the best!
Guy's
A little "play by play" update as to what is going on. The Dealer just called and said they checked the front sprocket and said it was good.... so that's not the problem. Also, just my luck when they took it for a test ride they didn't hear it slipping either. I told them to hook the Freedom trailer up to it, get out on the highway in 5/6 gear and get rough with it and I would think it should slip then.
The only thing they found wrong so far was the belt was really loose ......Could the belt have been slipping a cog on the front sprocket? I doubt it..... I'm grasping at straws here.....I'm Still thinking it's internal. I should have more updates in a few hours.
P.W.
IMO if that belt had been loose enough to slip a cog, you would most certainly have noticed. And the belt damage would be
easy to see. If a cog belts slips, one or more to the cogs get torn off the belt.
Peggy and Howard
Well, it wasn't my imagination, upon taking it for another test ride the dealer did experience the 6th gear slippage I was talking about.
So they hooked the bike up to the computer and it did show a clutch slippage code on the tranny. They did three kind of updates to the bike and took it for another ride and this time it didn't slip, so maybe they fixed it? I told them to keep it for a week or two and drive it as much as they can to see if it slips again.
Now my question is..... are my clutches bad, or going to be bad early from slipping??? (I would have to think yes).But I guess it's all documented now if something were to happen down the road....Good thing we bought the extended warranty at the time of purchase back in 2019.
I'll keep you all updated if anything changes...
P.W.
You would think that if they checked the codes and confirmed that it was indeed slipping that the same codes would have been there when you 1st took it to them. I'd wager that they never even checked them.
Good luck.
Good point! Why didn't they check for a slippage code right away when I rode it into there shop on day one??....Well I guess it's a good thing this is all being documented right now at this time...may need this info in the future for tranny work.
P.W.
When you changed your oil did it smell like burnt toast,if so then yes youre clutches are probably burnt.Another sign of burnt clutches would be chattering due to plate warpage.It is possible for a clutch to slip for a short time without overheating to the point of failure.Every time you pull out from a stop your clutches are slipping under load until they lock up completely which could take more than 1 second,and every time you shift there is a short period of slippage.With auto transmissions there is a computer parameter called clutch volume index in which the computer can measure the life span left in your clutch pack and adjust for a worn clutch.I dont know wether the Spyder has that capability but the dealer tech should.
: 2017 RTL ORBITAL BLUE
The oil was fine when I changed it, no burnt smell or anything stuck to the magnet...clean as a whistle. So maybe I lucked out with smoking the clutches....time will tell.
I just hope they got it fixed right on the first visit, so I'm not driving 2+ hours, one way to the dealer all summer long to get this resolved.
P.W.
Good luck!!! Ride it like you stole it!!!
