Results 1 to 8 of 8
    Jun 2015
    Ritzville, Wa
    Default Is it OK to add anti-freeze to coolant?
    To add anti-freeze to the coolant tank to make sure it doesn't freeze and crack?
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Bossier LoUiSiAna
    U know what color antifreeze? Don’t wanna mix wrong color /type
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2019
    southwest oHIo
    It should already have some in it. It's just the reservoir for whatever is in the engine. It's not going to freeze.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by gkamer View Post
    I see no reason why not. If you don't have an antifreeze tester, I wouldn't add much, perhaps 1/8 cup at most. I believe you got the Ryker new this year; if so, it has a 50/50 mix in it which is good down to minus 34 (I think).
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2020
    Platte City, MO
    A tester is only a few bucks. Pick one up and check the coolant. Too much anti-freeze is not necessarily better. It will keep
    it from freezing to a lower temperature, but may not cool as well when riding weather is back. Check it and don't guess, you'll
    sleep better.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Sep 2017
    Durham,Maine
    Unless you have put straight water in your system witch most people would not do these days, you have nothing to worry about it's not going to freeze!
    2012 RTL , Pearl
    Aug 2007
    Greeneville, TN
    Unless you have changed something. Or, the coolant is old. I don't see any reason to add anything to your reservoir. If you overfill it, you're going to have problems when the coolant comes to operating temperature and overflows the reservoir. If your coolant is good, there's no reason to mess with it. If it isn't, you need to drain, flush and replace it. If you replace it, you can use pretty much any product you want as long as it is silica free and aluminum friendly (which is the same thing).
    The only other possibility is that you may be confusing anti-freeze and coolant as 2 different products. Actually, they are 2 different names given for the same product. Coolant and anti-freeze are one in the same.
    Jun 2015
    Ritzville, Wa
    Great, I guess that's one less thing to worry about. Thanks for the comments.
    Greg Kamer
