Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Jun 2015
    Ritzville, Wa
    Default Suggestions to winterize my Ryker
    Thoughts from anyone on proper methods for winterizing my Ryker.... Special precautions, tips, tricks etc. I only have an unheated, no power storage shed available for my use not a nice heated garage.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Sep 2019
    illinois
    Quote Originally Posted by gkamer View Post
    I can only tell you what I DID last early November to prep for Winter, so I'm open for suggestions also. #1, I changed oil (at 3100 miles), #2, Added "Sta-Bol" to full fuel tank. #3, Stored the battery in the basement (up off of floor) with battery tender in use. Battery strap almost impossible to unhook. This year I will remove front apron? to get to it. #4, Bought 4 scissor jacks while on sale and got tires up off of my unheated wood floored shed. No permanent electricity in shed. I run a cord out to it once in a while, I also bought a "FlashFish" (Amazon) for the battery tender (22 hrs before charging) during the riding season. BTW I'm in Northern Illinois, 70 miles west of Chicago. (Have not been in there for est. 40 years.)
    https://www.amazon.com/Portable-Flas...s%2C190&sr=8-5
    Feb 2020
    N. Wilkesboro, NC
    I ride year round but at least you've got a shed. I don't have so much as a lean to.
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by MONK View Post
    I wish I was as lucky as you.... But I did buy a Can Am 1/2 cover that I used while it was parked outside the apartment. Worked pretty well.
    Greg Kamer
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by canamryder View Post
    Good suggestions, thanks. I don't think the jacks idea is going to work for me because unless the temp is sub zero or there's snow on the ground, I'm gonna pull my Ryker out for a little ride.
    Greg Kamer
    Jul 2014
    Mint Hill, NC
    ...I'm gonna pull my Ryker out for a little ride.
    Be certain to ride far enough EVERY time you take it out to get the engine oil fully up to operating temperature. If you don't do this you run the risk of getting condensation in the oil.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Feb 2020
    N. Wilkesboro, NC
    I cover mine whenever I'm not riding. One of the reasons I moved down here to NC from NORTHERN Indiana was to get away from "winter". A couple winters ago, we got 2' of snow all at once. Worst snow in 20 years from what I've heard. To me (coming from where I did), it's was more like.............a Tuesday. Last season we got a grand total of 1.5". I was NOT upset. I rode every week this past year (at least since February when I got my RT). I don't ride in snow (although I know a few who do) and I damn sure don't ride when there's ice. (I don't even drive my car on ice unless it's an emergency.) When I lived up north, I didn't ride much in winter until the rain washed the salt off the roads. That crap can do nasty stuff to anything.
    Jun 2015
    Ritzville, Wa
    Hahaha, not a problem for me. My definition of a little ride is 50 miles minimum.
    Greg Kamer
    Aug 2019
    southwest oHIo
    I have heard that the best way to "winterize" is to move south.
    Since that's not going to happen for me, I just add some Sta-Bil to the fuel. For my carburated rides (and other machines), I will double-up on the dose, then run the engine long enough to get the treated gas through all the different circuits in the carb(s). Have not had a fuel-injected "toy", but will probably use some Sta-Bil in it, too.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Jul 2014
    Mint Hill, NC
    That's a good definition.
    Cognac 2014 RT-S
    Invalid Emails
    Sep 2020
    Simcoe ,Ontario, Canada
    I'm lucky, mine sits in the Garage all of the time. It is always cleaned and covered after every ride. It sits on a battery tender all of the time. As the weather changes and temps drop here, the fuel tank is always full with added stabilizer. , i pick my moments to ride. Up until recently i was only home every 10 days or so, unfortunately do to health issues i have been moved into early retirement .... may be next year i will be able to slap down a whole bunch of miles.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Last winter I added sta-bil to my gas tank and then drove it for a while. Parked in garage and hooked up a battery tender. That's it.
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by Markubis View Post
    I'm gonna do that. I don't know if I can sta-bol around here but I'm gonna find a good gas treatment to drop in and take her for "a spin" to get the treated gas through the system. Thanks.
    Greg Kamer
    Oct 2020
    ontario
    Do you need to disconnect the battery terminals when using a tender for the winter?
    Sep 2020
    Platte City, MO
    Quote Originally Posted by mark99 View Post
    I don't.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Aug 2020
    Kent, Ohio
    I don't either, my battery tender harness is always connected to my battery. so park it and plug in it! that simple....
    Aug 2019
    southwest oHIo
    I don't know if I can sta-bol around here but I'm gonna find a good gas treatment to drop in ...
    I would be surprised if you couldn't find it. Around here it's available at every auto parts store, Wal-Mart, even at the grocery store.
    HER ride:
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    May 2019
    Washington
    you should try Star Tron it is a far superior product for gas with ethanol to sta-bil, Also storing a battery on concrete is not as big of an issue as letting dust gather between the negative and positive polls.
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by Steve W. View Post
    Yup, I found it at Walmart, $8+change
    Greg Kamer
    Jun 2011
    Alamogordo, NM
    With out doubt, the very best way to winterize is to spend the Winter in Arizona.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Invalid Emails
    May 2021
    Ontario,New York
    We are almost to the winterizing time of the year again !
    Active Member ziggy's Avatar
    Apr 2021
    North Carolina
    Old man now, but when I lived in Japan,40 years ago, I rode my Honda more than I drove a car. Even rode to
    work every morning in the snow . Now I'll ride three wheels,,,,,Much safer
    I'll ride less, I'll use a trickle charger but I'll still ride in the winter.
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Last year I took the battery out and added fuel stabilizer. This year I bought a battery tender and will leave the battery in. It's a royal pain to remove the strap and worse putting it back on.
    2021 RT Base - Petrol Blue
    Jan 2009
    austria
    I didn`t use a battery tender in the last two winters - also after 100 days she still startet perfect, but after the start I immediately make a 60 miles trip to reload it full ..
    and if you need a good route for this - ask me
    https://www.youtube.com/watch?v=GpzlbmtkLbQ&t=3s
    Sep 2017
    INDIANA, USA
    Default Winter The Spyder
    Well, some good information.
    I have a battery tender on the battery during the months of November through April.
    I am located in good ole Indiana. .......
    The last couple of years I've been able to get a Ryde in two or three days a month. I still use a fuel stabilizer for added gas protection.
    My Tip. ......
    ENJOY YOUR LIFE WITH A SPYDER
