Results 1 to 6 of 6
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Default 2015 RT analog gauges intermittently not working
    I have a 2015 RTS.
    The analog gauges (gas & temp)have started not working intermittently. When the analog gauges aren't working the ones built into the digital display are on.
    I took the dashboard out and checked to make sure they had not come unplugged, everything seems tight.
    What could be causing this ?
    I'll have to check back periodically, because I'm not getting notifications.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Jul 2014
    Mint Hill, NC
    Load test your battery.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2013
    Quote Originally Posted by ES44AC View Post
    That'll be because you've set the 'receive email notifications' button to 'NO' in that block of your profile - you can change that simply by clicking on the 'edit profile' link when you open up your inbox.
    Since you were able to post the original post above that started this thread, you WILL also be getting the number of unread msgs showing in the 'Notification' block right up the top right of every screen once they paint up; it'll show a Red number alongside the word 'Notifications' which appears above the Lamonster Garage Emblem & just to the right of where you can see the 'Welcome ES44AC' msg & to the left of 'My Profile', 'Settings', & 'Log Out'
    As for your gauge problem, the digital gauges only show if BOTH analoge gauges aren't detected as being connected at any given time, so if it's not the battery as per JayBros' suggestion (which is a distinct possibility ) then you've probably either got an intermittent fuse or wiring/connection issue, or BOTH gauges are somehow coincidentally & intermittently failing/disconnecting at exactly the same time.... I'd guess at it most likely being the former & not very likely being the latter, but it'd only be a guess.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member ris's Avatar
    Jun 2016
    N.H.
    I had the same problem. I have a 2015 RTSE6.
    The dealer had to change my entire dash.
    Sep 2015
    Mocksville,NC
    I got it fixed in March. It was the entire gauge package. This did fix the issue for sure.
    I got to looking at the 2021 RTL and I traded the 2015 RTS in.
    Lamonster Riser
    Mar 2019
    WA
    I ended up just removing both gauges and getting blanks that fit into the gauge cutouts. Even when Spyder analog gauges work they're not accurate and finicky. I find the digital gauge to be more convenient.
    The ones I went with:
    https://prosportgauges.com/products/...h-silver-bezel
    Plan is to attach a RAM mount for iPhone on one of them and a dual USB port on the other.
    https://www.amazon.com/Outlet-Charge...8610725&sr=8-3
    2011 RT-S , Blue
