The Kuryakyn 4393 Mini boards are BRAND NEW, never installed. They will require a proper adapter (<$30) for your particular application. The adapter allows for rotation of the boards to your desired position. As I read it on Kuryakyn website, these will fit FRONT OR REAR with proper adapter (see post below) $50 shipped CONUS
3rd pic shows how the adapters can be fitted in any of 3 positions front to back, then can be rotated to adjust foot angle.
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Kuryakyn depends on the splined adapter that you use. I copied this off their site (I will have to correct my opening post):
FRONT OR REAR APPLICATIONS
P/N Description & Fitment UOM Price
8808
Splined Peg Adapters for Can-Am, Honda & Suzuki, Chrome Can-Am: '08-16 Spyder RS Models
SALE:
$26.99
Orig.$29.99
This one does NOT state that it is front and rear, but it appears to be just the black version of the 8808
8889
Splined Peg Adapters for Can-Am, Honda, Suzuki, & Triumph, Gloss Black Can-Am: '08-16 Spyder RS Models
I had these listed a quite a while ago, and forgot about them. In my brief absence from the Forum, some members inquired about them, but I was unaware. So, here they are for sale.
The Rivco CA-125 floorboards would not work for me because of my Corbin Saddle Bags. THEY NEVER LEFT THE GARAGE! There are slight polishing marks on the brackets that were necessary to slip them into the Corbin mounts, but they will not show. These are for PASSENGER position. They were $230 new. I'll take $100 SHIPPED!
The Kuryakin 4393 Mini boards are BRAND NEW, never installed. They will require a proper adapter (<$30) for your particular application. The adapter allows for rotation of the boards to your desired position. CORRECTION: As I read it on Kuryakin website, these will fit FRONT OR REAR with proper adapter (see post below) $50 shipped CONUS
Honestly not sure that RIVCO are still available new
If you are considering the Kuryakyn set for REAR, I would suggest checking with them for clarity.
Using the link below to an online site the Rivco’s show 4 pins online- do you have those as well?
Hey AVBIZ!
Thank you so much for bringing that up! I DO have the 4 pins and just forgot about them!
They are actually installed on the bracket arms in the pictures I posted. There are 3 holes on each side of the center threaded mounting hole. The 4 pins appear in the pics as dark spots in the middle holes of the three.. If you expend the pictures you can see them sticking out toward you.
Thanks again for the heads up!
