Results 1 to 21 of 21
    Active Member plescaille's Avatar
    Jun 2012
    New Egypt
    Default 2012 RT Limited wont start after replacing battery U0300 Code
    The battery on my 2012 rt Limited completely went dead. I went and purchased a replacement, put it in and here is what happens.
    1. It powers up , however i do not hear the typical fuel pump priming.
    2. All lights work and it asks to hit the mode button as usual.
    3. The Kill stitch is in the proper position.
    4. When I step on break and hit the start button nothing happens.
    5. I opened Frunk and when i hit start I do hear some clicking on the relays. I also verified all fuses in 3 locations are not blown.
    6. I am getting an error code U0300.
    7. Have the battery is fully charged and all connections are tight.
    Any suggestions would be greatly appreciated.
    Best Regards
    Pete
    Pete
    Fortune Favors The Bold!
    Sep 2020
    Platte City, MO
    My service manual for Peggy's 2013 STS shows that U0300 is "Invalid security exchange received".
    One action listed: "Update security coding using B.U.D.S."
    Looks like a visit to the dealer may be necessary. A phone call at the least.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Jun 2012
    New Egypt
    Uggghhhhhh. Thank you. of course the Dealers are all closed today.
    Pete
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    I’m thinking about the possibility of a system spike when reconnecting. First thing is try is disconnecting, wait until everything dies, then reconnect. If you get the same code, then it sounds like the dealer needs to get involved
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Sep 2020
    Platte City, MO
    Is it possible you reconnected the negative terminal first? That might explain a power surge/spike when the positive cable was connected.
    Peggy and Howard
    Jun 2012
    New Egypt
    Definitely did not reconnect the Negative first . SO you think that if I disconnect the battery for a while then reconnect it may clear?
    Pete
    Sep 2020
    Platte City, MO
    Give it a try, surely couldn't hurt.
    Peggy and Howard
    Jun 2012
    New Egypt
    I will let you know.
    Pete
    Jun 2012
    New Egypt
    So I disconnected everything, ate dinner, came back and reconnected but "no go". It wont start and the same U0300 code. I wonder if the security features of the electric chip on key can be disabled?
    Thanks again for the suggestion.
    Pete
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Did you look up the various threads about the DESS modules? Therein may lie your problem and solution.
    2020 RTL SE6
    Jul 2011
    Mitchell, Ontario, Canada
    Not sure how the discussion has gotten to the key chip or DESS module. Wrong systems.
    U0300 Invalid Security Exchange Received.
    Possible Cause
    Incorrect ECM or CLUSTER,
    Incorrect software version.
    Service Actions
    Install the proper ECM or CLUSTER on vehicle.
    Since you do not mention replacing the ECM or Cluster. Looks to me to be the ECM and Cluster do not recognize each other anymore. Some data has become corrupted. Plug it into BUDS and see if they can made to talk to each other again.
    2018 F3 LIMITED
    Jun 2012
    New Egypt
    Thanks waiting on a friend with BUDS to come over. Was hoping there was a workaround but i do not think so...
    Pete
    Jun 2012
    New Egypt
    Is there any other possibilities to correct this without the BUDS? Tuning Switch on and off several times? Jumping up and down while rubbing belly? anything??
    Pete
    Dec 2013
    Quote Originally Posted by plescaille View Post
    If it's the ECM/Dash/Security thing that seems to be most likely, then NO.... your only real option with this at this stage is BUDS - or a new/replacement Spyder.
    Sorry!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Jun 2012
    New Egypt
    No need for a new one. Buddy came over with BUDS and its all good Thanks for the help to everyone. I have not been on here in years but still remains a great community.
    Best to all!!
    Pete
    Aug 2012
    Central Coast, CA
    Possible Cause
    Service Actions
    It was a SUGGESTION to read the threads for a POSSIBLE insight into the problem. Having never had either problem I was spitballing for a POSSIBLE solution.
    2020 RTL SE6
    May 2018
    Chateauguay, Qc, Canada
    Best to all!!
    What did your buddy do to make it all well again?
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Active Member AVBIZ's Avatar
    Oct 2019
    Roswell, GA
    Best to all!!
    Are those BUDS units that expensive- saw one on Amazon for $700+....
    1973 Honda CL 350 Scrambler (given to Son)
    2018 Vespa Primavera (Wife’s ride)
    2008 Spyder GS
    2020 Piaggio MP3
    Jun 2012
    New Egypt
    They are expensive but I do not know how much he paid. He is also a mechanic and has experience with the software. I believe he re synced the ECM with the cluster and then applied the updates which were lost.
    Pete
    Jun 2012
    New Egypt
    Now my issue is that my blinkers are flashing fast. I have tried Lamonsters rest but it has not worked. have to try again tonight. i know there is a way since i resolved it originally(years ago) when i added my led's. just frustrating especially when i do not have a lot of free time. looking through old post now since mine is a 2012
    Pete
    Jun 2012
    New Egypt
    Update on the hyper flashing. As it turns out I checked all my connections and one of my mirror connections was the problem. If people are unable to resolve a hyper flash using the prescribed method I strongly suggest they double and triple check all connections.
    Pete
