Results 1 to 9 of 9
    Active Member tbohman56's Avatar
    May 2020
    Greenwood, SC
    Default K&N Filter Does Not Fit Ryker CVT Side
    I know the filters on the Ryker are the same size, and I have a K&N on the intake, but when I tried to fit the K&N on the CVT side, it is such a tight fit that it puckers on one end, and does not provide a complete seal. Anyone else same issue?
    Currently Own: 2019 Ryker Rally
    Previously Owned: 2019 F3 Spyder
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by tbohman56 View Post
    I have both filters on my Ryker with no issues. Be sure both are CM-9910's. There are filters which look identical but are not. Next, I would swap air filters. If the problem then moves to the engine side, I'd say you might have a defective air filter. Though in all my years selling and using the K&N filters, I've not seen a defictive one. But anything is possible.
    I would be very interested in what you discover.
    May 2020
    Greenwood, SC
    Problem solved. They sent a KT-1113 filter in the CM-9910 box.
    Aug 2007
    Greeneville, TN
    How about that! Never saw that before. But like I said. Anything is possible. Glad you got it worked out. I really like the K&N on the CVT side. I was getting a hot belt smell until I changed to the K&N. It's warmer temps now than when I got the hot belt smell. Found the stock paper air cleaner pretty well clogged after only 2,000 miles. I've been advising people to keep a close eye on that CVT side. The cooling fan on the CVT side must really pull in a lot of air.
    The fact that the K&N will flow more air dirty than the OEM paper filter when it is clean is a good thing.
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    Can you work the mesh where it binds?
    The aftermarket filter on my trans was an easy fit.
    Disregard, just saw wrong filter in box post and deleting is not an option.
    23 Moto Guzzi V7-850 SE 23 Yamaha XT250 18 Yamaha Bolt R-Spec 22 Triumph Street Twin 20 CanAM Ryker 900 14 Honda CB1100 18 Yamaha XT250 16 Moto Guzzi V7 II 17 Yamaha TW200 12 Triumph Bonneville 02 Sportster 1200 Sport 03 Sportster 883 76 Honda CB750F 75 Honda CB360 70 Yamaha CT1 72 Yamaha CT2 72 Yamaha AT2/CT2 70 Honda SL350 70 Honda CL350 67 Honda CL160 67 Honda CB160 62 Honda CA110
    2020 900 , NGK 4218 iridium CR8EIX Matte black
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by SportsterDoc View Post
    I see you went about 5k on the original air filter. How dirty did you find it to be?
    May 2020
    New Mexico
    Moderately dirty.
    I could have removed, blown off bugs (from backside) and used another maybe 2,000 miles.
    However, as important as cooling is to the CVT belt, I had already decided to go only 5,000 miles.
    I had just returned from a six day 1,115 mile trip, including 10 miles of dirt road from Williams (AZ) to Highway 89A and 1/2 mile dirt to friends in Prescott Valley.
    Looking at the oil, I am glad I did two oil changes already, at 1200 miles and 5,622 miles. If I were to keep it, next would be in 5,000 miles at ~11,600.
    Even though I am planning on selling the Ryker (hence the service items for sale ads), I treat every vehicle I have owned as though I planned to keep it forever (that gives my wife a good laugh).
    Active Member threewheelcurious's Avatar
    Apr 2013
    MID MISSOURI
    Default Happened to me as well!
    2019 600 ACE , Yellow
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by threewheelcurious View Post
    That is really amazing! I'm going to check the filters we have in stock to be sure we aren't sending out the wrong one. But I do highly recommend the K&N on the CVT side. It will make a longevity difference as well as a functional difference in the operation of your CVT.
