air horn for 2018 F3T
Has anyone replaced the stock horn with a mini air horn? If so was it as simple as connecting 2 wires?
You could try that but consider the fact that the air compressor for the air horns will draw considerably more current that your present
OEM horn. It might work for a short blast, but more than that may cause issues with the horn button, or the wires. A much wiser choice
would be to wire in a relay, and not take any chances.
Peggy and Howard
Hers: 2013 Spyder ST-S SM5
Just go into the F3 maintenance section and search the forum for air horn. You'll get a couple of pages of how to on air horn install.
The horn button completes the ground, the hot +12v is always hot even if the key is off.
