Results 1 to 7 of 7
    Apr 2017
    Queensbury, NY
    Default Hard to Lock Gas Cap - what works for you?
    It's been quite awhile since this happened to me, but today I had a HELL of a time closing/locking the gas cap on my 2016 F3T. I know that it can be improved by quite a bit thru the application of some sort of grease/lube, but I don't remember what I used last time. So what works for you? Would Silicon Grease work?
    Note: I DON'T want to replace the cap with a 3rd party device.
    Thanks!
    Bert
    Feb 2019
    Portland, Oregon
    You are going to get replies to apply various lubricants. Although they will afford a little help, the real solution is to take the cap apart and remove the latch, as that's the culprit. The top surface of it is too high, so file it down about 1/16" + and that should do it. If not, take it down some more. This worked for me. Like you, I wanted to keep the OEM locking cap.
    IMPORTANT - place a rag in the neck so cap parts don't end up in your tank.
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    yes Silicon Grease would work used it om wife bike
    2019 f3t , titanium
    Apr 2019
    Florida Swamp
    Turn key, push down, it always latches.
    2019 F3-S , Black & Silver
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Quote Originally Posted by Gwolf View Post
    This is way too easy ... it works for me also every time on my 2016.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Sep 2013
    Houston
    Lubricate the sliding latch bar that is beveled on the end. We use a product called TriFlow that works very well and lasts far longer than most other lubes that wash off from gasoline.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2009
    La Valle, WI
    As others have said. Lube the seal and latch. Vaseline petroleum also works. But most importantly turn the key clockwise all the way. Then push down and return key to home position. Will latch easy every time.
    2018 F3 Limited , Oxford Blue
