Results 1 to 10 of 10
Thread: Tire pressure
    Active Member sandylolee's Avatar
    Oct 2019
    NC
    Default Tire pressure
    Just replaced my rear tire with a General Altimax. My rides are mixed with single and double up rides. What tire pressure has worked best for others with this tire.
    2019 Rt limited chrome , Phoenix orange
    Quote Originally Posted by sandylolee View Post
    First my comments are for ANY Auto tire on Any Spyder. Over the years I and Peter Aawen have narrowed the REAR psi to an average of 18 lbs. .... If the rider is 175lbs. and you Add another 200/ 250lbs..... I would Only add ONE lb. .... will that small an amount make a difference - Yes, but you won't be able to tell the difference .... to me it's not worth the trouble because the result will be very, very minor..... good luck .... Mike
    Jul 2014
    Mint Hill, NC
    I run my Altimax w/- 21 lb, weigh 185 and most always ride solo. Were my wife to ride I would stay with 21 as she's a lightweight.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    ..... try 18psi, that tire is fine at the lower PSI, and it could feel a bit more comfortable to boot ..... Mike
    May 2017
    Mesa, Arid-Zone-A
    I ran that tire on my 2014 RTL. I aired up all 3 tires to 18#s. I know I could have run less pressure in the fronts but 18 worked for me and I had only one number to remember for all the tires..... Jim
    Semper Fi
    Oct 2016
    Faribault, MN
    +1 what they canamjhb and BlueKnight911 said
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Northern Kalifornia
    That's 18 cold. At highway speeds the PSI can easily increase 4 PSI (or more) at 90/100 degrees.
    Sep 2016
    Chillicothe, Oh.
    Another vote for 18 all the way around. Federals on front and Altimax on rear. Two up 99% of the time. Works for me.
    2015 RT , Black
    Yes I know all about the pressure change thing ( so does Peter Aawen ) that's why we recommend 18 PSI .... COLD ..... Mike
    Northern Kalifornia
    True, but some don't. Sorry to ruffle your feathers.
