Results 1 to 8 of 8
    Apr 2013
    Australia
    Default F3 sluggish takeoff
    Hi folks
    I have a 2016 f3 limited and it’s started to be sluggish on take off
    Spluttering and not smooth at all
    Also when it idles it’s not constant, it goes up and down
    Sorry for the non technical Descriptions
    Anyone able to advise
    Cheers
    Not much go go on here. How many miles on the odometer? Any recent service or modifications? Has the recommended maintenance been done? Has it sat for a length of time? Did this begin right after a fuel-up?
    Could be a fuel filter issue. Could be fuel injectors, bad gas, or even worn or fouled spark plugs. Especially if you have been lugging the engine. Could even be ECM problems.
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    How many miles? Could be that the throttle body needs cleaning, spark plugs or poor quality fuel. Might want to try some fuel injector cleaner, like Seafoam, and try that first.
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Apr 2013
    Australia
    Sorry for the late reply I’m in Australia
    It’s done 4,000 kms = 2,458 miles I guess
    I have put 350 kms on it since I have had it for 3 months
    I’ll try the fuel injector cleaner and see how that goes ��
    Feb 2019
    Portland, Oregon
    Try not allowing the revs to go below 3,000, preferably higher. Shift at 4500 or more. As Martin the vlogger says: Ride it like you stole it. The 1330 engine love to rev and thrives on it.
    Also, give it a good warm up prior to taking off. Start it, then put your gear on.
    Quote Originally Posted by Hutch View Post
    With this kind of mileage. I'd lean towards bad gas. Maybe a clogged fuel filter if you got a load of crud from a fuel-up. Let us know how the fuel system cleaner works for you.
    Apr 2013
    Australia
    So an update
    I have been using nulon octane boost and clean
    Went well for a while then had to add more
    Now it seems like I need to add it to every tank fill
    What I have found that it starts to rough idle if I’m in city traffic being stationary on a regular basis
    I’m now at 7,000 kms
    Very frustrating
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Do you fuel up, at he same gasstation???
    It's definitely not good to, use that much octane boost, cause your fuel is getting burnt at hotter temps, and this will cause failure to the injectors, they could easily burn completely out.
    Try and flush the tank, with a good octane fuel, put in a new fuel filter, and basicly check fuel flow.
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
