Results 1 to 11 of 11
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Deleted
    2020 RT , Lamonster extender Petrol
    Sep 2020
    Platte City, MO
    How do you figure this is your fault? If you used the proper sized Torx and it wasn't made out of aluminum, then the part that is at fault is the drain plug.
    Unless you were using a 2-foot cheater and couldn't feel that the bit was going to turn in the bolt. Just don't tell them you were turning it the wrong direction.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Feb 2019
    Portland, Oregon
    Use a ratchet and always, always, always check its rotation before putting it on the fastener. Especially when loosening down facing fasteners. 9 guys out of 10 will turn one the wrong way. I know, I trained repairmen.
    Sep 2020
    Platte City, MO
    Deleted?
    Peggy and Howard
    I think we can still get the gist of what was posted.
    We will be okay to delete the thread if ButterSmooth requests it.
    Sep 2020
    Platte City, MO
    I hope he didn't think I was criticizing him. I certainly didn't mean it to come across that way.
    Peggy and Howard
    Quote Originally Posted by Possible View Post
    No problem here. Nothing implied IMO.
    Feb 2020
    N. Wilkesboro, NC
    Bro, I've done far worse. Search for my username and read some of my threads. To say I'm mechanically challenged would be putting it mildly. If all you did was twist a drain plug the wrong way, you're still having a better day than most of mine.
    Sep 2020
    Central Oregon
    I deleted the post because a half hour later I fixed it. Applying as much pressure to the wrench as I could, before it would slip, I smacked the wrench with a hammer (not in the turning direction, but down into the bolt), much like the old manual impact drivers we used to use. On about the third hit the plug broke free. No worries for anyone posting here. You can't be as hard on me as I can.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by ButterSmooth View Post
    I hear you loud and clear on that one. I am my own worst critic. I even swear at me!
    So glad it all worked out good and well. When I did my first oil change, I too, had to "pop" the plugs loose.
    Most of us have been there and done that when it comes to anything crazy with the Spyder.
    Thanks for posting about your solution. We appreciate the input. Maybe the next time it happens to someone else, they will see this and have good information on the fix.
