Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
Thread: Pedal Commander
  1. #26
    Aug 2018
    Piperton, TN
    What is a stage 1 tune and a pv3? Sorry, newby here.
  2. #27
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by ollicat View Post
    Stage 1 (and stage 2) are ECU flashes done by Monster ECU or Wick-It. The PV3 is a Dyno Jet Power Vision 3 tuner.
    2022 RT Sea To Sky
  3. #28
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    hey troop...before the winter fall...take your bike to the dragstrip...run some times with and without the pedal commander...i want to see your R/T with and without the commander, since you have a dynojet...by what I have read so far, nobody has done this yet....really run it with a tune and commander combined...get actual timed runs.
  4. #29
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    O.K., I think my main question would be does the unit open up the throttle limits.
    I generally take a couple long road trips a year and I will not ride behind a 18 wheeler.
    My 2015 F3l was a hot rod and twisting the throttle would get you past a 100 in a heartbeat
    In 6th gear. That's what I am looking for in a s\w upgrade.
    Dray
  5. #30
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by 308gunner View Post
    Yeah ... Sorry, that's not gonna happen.
    2022 RT Sea To Sky
  6. #31
    Jun 2020
    NW Suburbs Illinois
    My friends got one on his F3 limited plus a stage 2 monster tune, he loves it, definitely gets touchy at the higher settings. I got one on my Ryker and I'm afraid I'll need a rear tire soon.
  7. #32
    Oct 2017
    covina california
    Too late in the season..well...next year!!
  8. #33
    Dec 2014
    Graham Tx
    Does the PC remove ECU control of limited top speed. My 2015 F3L would do
    115 mph, my 2017 F3L was limited to about 98 mph. My 2020 RT has not had
    a top speed run as it is new. It will do a quick run up to 100 mph and I am hoping
    for more once I get more miles on it.
    Opinions appreciated!
    Dray
  9. #34
    Quote Originally Posted by Dray View Post
    Dray
    NO!
  10. #35
    May 2018
    virginia cape charles
    does the pedal commander over come the onboard computers ability to control the throttle plate opening?
    2021 f3l , large pedal pad and lamonster lowering rod liquid titanum
  11. #36
    Quote Originally Posted by pam135 View Post
    NO! It simply intercepts the 'fly-by-wire' throttle signal & enhances that signal before it hits the ECU to make your throttle input produce a 'quicker result' in engine response.....
  12. #37
    Oct 2017
    covina california
    I just ordered a Pedal Commander to go with the Stage II tune...It should be interesting.
  13. #38
    Aug 2018
    Piperton, TN
    Keep us posted
  14. #39
    Jun 2011
    Alamogordo, NM
    What comprises a Stage II tune?
    Where do you get a Pedal Commander?
    Thanks.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
  15. #40
    Sep 2020
    Middletown, NJ
    2020 RT base , Chalk White
  16. #41
    Oct 2017
    covina california
    The Pedal Commander is fantastic ..the commander and the stage II tune work hand in hand...
  17. #42
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    Just ordered a pedal commander from Slingmods - it's on sale ($50 off)
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
  18. #43
    Jul 2020
    Florence, sc
    Installed pedal commander on 2019 f3L. First crank after installing received limp mode with throttle position sensor voltage too low. A few ignition crank cycles and the code cleared up and works great. Only test on Sport mode with no extra settings and the tire will spin from start off. No other modes have been done except akropovic exhaust. It seems now that 100% of throttle is actually about 80% of a twist. What I mean is u can give the throttle a twist while riding and u can normally tell by engine sounds if you are applying any more fuel to the fire but after about 80% twist with pedal commander on Sport the last 20% is dead air. Even with that said, it's still fun to finally be able to spin tire without having a sport mode like standard F3S. Of course now that's means I will probably use up back tires more frequently that without the PC.
  19. #44
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    Quote Originally Posted by nightcruiser View Post
    You can put it on yourself in about 15 minutes,,just pull one panel and one speaker cover. it's plug and play. Does take the Nanny a few miles to fine tune but she doesn't complain from the start.
    two panels counting the one underneath. Seems to me like the more you ride it the better Nanny like it.
  20. #45
    Feb 2019
    Indiana
    Quote Originally Posted by mcalva View Post
    To the detriment of the opinion that you cannot give your opinion without trying, I would say that the experience of others tells us that we should not try skydiving without a parachute, i.e. So we can say that the idea does not seem very good even if we have not tried it. Just as the experience of others can explain to us that roasted ribs are delicious, so our opinion may be favorable even without having tested them.
    All this without the intention of creating controversy if not the opposite. Of course.
    I think the initial question is already answered. You will achieve a faster delivery of benefits regardless of the map you have configured.
    LOL, whew
  21. #46
    Mar 2018
    Danville Ky.
    hi Indiana.. from KY>
    I have been traveling last couple of months... yes difficult in todays world..
    i have the Pedal commander sitting on my seat when i get home. I am super excited to install and get the quicker power! I am looking for a quicker start.. especially pulling a trailer from a dead stop.
    Example:
    *Pulling a mountain with a 500 lb trailer in tow... manual throttle i could not hold 70 MPH... dropped to 60 and down shifted.. .of course.
    * Same day i went back up same mountain with cruise control and the spyder lost 2 mph. She just pulled the mountain at 68 and never whimpered .. i really did not notice until second sweeping curve. i was thinking what the hell... cruise had more throttle than i do manually?
    my point is the Nanny takes away power but allows the cruise control to have more power / throttle what ever.
    jim
    I want to pulls same mountain and see if Pedal commander possible will allow me to have more throttle etc...
    2014 RT Limited , stock lamonster flat silver
