Results 1 to 12 of 12
    Nov 2008
    las vegas, nv
    Default pulling freedom trailer with Rs
    was there a proven hitch for RS to pull a freedom trailer and do i have to rig my own wire or is there a pre-made ones?
    i saw couple of hitches on eBay but i don't know if they actually would work properly.
    thank you in advance.
    6 states down 42 states to go
    Bossier LoUiSiAna
    Believe there are both harness & hitch please what year RS
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2008
    las vegas, nv
    2015 RS.
    It looks like choices are show chrome and USA trailer shop for hitches.
    Trailer shop’s is cheaper, $170 and comes with 1 7/8” ball(don’t know if that’s the right size for freedom trailer) and show chrome is $230-ish without the ball.
    I don’t know how much difference there are between two but show chrome’s is secured with 3 bolts on each side to trailer shop’s 2 bolts.
    Also, it looks like trailer shop’s mounts to existing axle but show chrome’s comes with long bolt( not sure if that bolt replaces axle)???
    Bossier LoUiSiAna
    Long bolt goes through axel not a replacement, least on most SPYDER hitches I’ve seen
    Late thought does the RS have “trailer mode” like the ST?
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    I towed a trailer with both my 08 GS and my 11 RSS, with no issues .... no trailer mode .... there were no " plug n play " connections at the time I made my own Hitches. So they were hard wired into the rear harness.... worked fine. When BRP decided to make a Hitch for the RT series Spyder, that swing arm and the ones on the GS & RS models were the same, and using the same motor. .... Either of the Hitches you mentioned will work fine for your RS ..... good luck ... Mike
    Nov 2008
    las vegas, nv
    Thank you both. I think I will go with USA trailer shops hitch for less and free ball if it’s all the same and hope that ball is the right size. ����
    I can make my own harness if I know which plug to get, I guess.
    Tapping into marker/brake lights isn’t hard.
    Nov 2008
    las vegas, nv
    i'm beginning to wonder if that long bolt makes it more sturdy to make it worth extra $60????
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    It makes it easy to install and remove the hitch without loosening the wheel nut
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Nov 2008
    las vegas, nv
    So hitch with long bolt installs without removing axle nut?
    So the hole on each side is large enough for axle nuts to sit in it or the bracket on each side just go over it?
    That will be a big plus!
    Quote Originally Posted by oldgoat View Post
    Bossier LoUiSiAna
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Sep 2008
    Yorktown, VA
    I used this adapter on my '08 GS. It works great.
    https://www.amazon.com/Hopkins-46365...omotive&sr=1-1
    Bruce
    Yorktown, VA
    '08 Spyder GS
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by aka1004 View Post
    Yes, had the show chrome on my 2014 worked great. Something to think about, that hitch is connected to the swing arm, lots of movement and shaking going on while towing; for WIW the three bolt gives you one extra bolt of security while towing. I used Posi taps to go into my wiring harness, never a electrical problem over three years.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
