Results 1 to 17 of 17
    Very Active Member SNOOPY's Avatar
    Aug 2013
    Default Is this a Shift or Idle issue?
    2013 STS SE5
    So what it seems to be doing is when on a ride, bike warmed up, if I stop for a moment such as at a light, when I go to take off...the bike shutters/hesitates (whatever you want to call it) looking for a gear to move forward. It is a split second but annoying. Bike should already be in gear right? It’s as if the idle is low and not keeping in first, if that’s even possible.
    Not sure if the throttle needs to be 100 rpm higher (if possible) or if some linkage needs to be adjusted?
    Or clutch wearing out? (If there is a clutch lol)
    Bike has probably under 18,000 miles.
    Sep 2017
    Durham,Maine
    Have replaced the two vac lines on the carb yet?
    2012 RTL , Pearl
    .... and The SE trans on the V-twins are fussy about the OIL level.... so had thast been checked ??? ..... good luck .... Mike
    Aug 2013
    SF Bay Area
    Oil level can make a difference. Check it per the manual. It's a cold blooded engine and once really warmed up it runs fine. The plugs and wires, if not changed, should be with the 14k service. Vacuum hoses should be OK as they are newer than the earlier models. But checking them for cracks would be a good idea.
    2021 F3 Ltd , Magna Red
    Feb 2012
    Spring City,Utah
    All VTwins come with rubber vacuum hoses that break down rather quickly. Regardless of miles your machine is over 7 years old. Change out hoses for ones made of silicone. You can get the hose at NAPA but you will have to cut them to length and they must be the same length as the originals. Check your oil, that can make a real difference in the shifting. At 18000 miles your clutch should be just fine unless you have abused it by shifting to soon and running the motor at too low an RPM.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2020
    Senoia, GA
    This may be a goofy question, but hey, this is my first Spyder. I have a 2013 SE5 RT, how many vacuum hoses are there? I have had the 'chug chug' at a stoplight once and have thought about having the hoses changed out. Since I have an uphill battle getting the techs to take me seriously when I mention something that is wrong if I cannot be very specific, I try and do my homework. If there are multiple, then I might say change them all while they have it apart. Thanks!
    Sep 2017
    Durham,Maine
    There are two, pretty close to each other, do a search on them, you will find some pictures so you know what your looking for!!! MAPS 2.jpg
    2012 RTL , Pearl
    Jun 2020
    Senoia, GA
    That is great info, thank you!!!
    Aug 2013
    To answer some of the questions above.. I have changed the vacuum lines to Bajarons silicone hoses, that was years ago and can recheck. Oil and filter changes have been done probably a little sooner than CanAms recommended time intervals and I check the level all the time.
    And I notice this more when all warmed up than I do when it’s cold.
    Aug 2013
    I don’t think my motor has ever been run at a low RPM.
    Sep 2017
    Durham,Maine
    Could it be misfiring? Like a bad plug or wire?
    2012 RTL , Pearl
    Aug 2013
    I could check that also when I check the vacuum lines. I changed the plugs wires and hoses a few years back w the upgraded stuff from Bajaron.
    But yeah, feels a little like that, but only from idle after sitting a moment.
    Aug 2013
    Just checked plugs and hoses. Plug color looks good. Plug gaps were about .033, i regapped to .030 (within spec of .028-.031). Torqued to 124 in lbs.
    Hoses looked like getting some age on them and not real tight so I replaced since I had more. Now a pretty tight connection.
    Didn’t find anything of significance, so don’t know if there will be a change. Rainy out, so can’t check today.
    Bossier LoUiSiAna
    Quote Originally Posted by SNOOPY View Post
    Think1300 RPM bare minimum on 998. When fighting purge valve issues, that was about where it would stall. Possibly what is going on if topped off gas tank too much.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Aug 2013
    Are you saying the purge valve may be the issue?
    I usually fill up at home w a fuel jug, so usually don’t over fill. But I can check that or replace if it’s a common issue. Where is it? Lol
    Bossier LoUiSiAna
    Wouldn’t say “common” but definitely troublesome & like BRP$500 Apparently can NOT get wet so naturally install on a FLUID container
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    Aug 2013
    2013 STS SE5
    So finally got a chance to ride it yesterday and it seems better. Only things I did was clean and regap the plugs and replaced the two short hoses at the carb w some fresh silicone ones. I’ll have to check on a warmer day or longer ride in case it’s still doing it when hotter.
