Spyder F3 SM6 Brake And Shifter Linkages +1 Position 4
I'm selling a set of F3 SM6 Brake and Shifter Linkages +1 Position 4, part# 219400564.
$35 shipped.
I'm looking for a +1 position 4 brake rod. I don't need the gear selector as I have the SE6. I assume I could still use the brake rod and it will work on my SE6.
Is it the OEM brake rod or an after-market one?
Yes it is an OEM set, and the brake rod is the same.
This set is still available.
