Results 1 to 19 of 19
    Feb 2019
    Uss
    Default Cruise control stopped working
    Help?
    Feb 2019
    Uss
    Default Cruise control not working
    Help?
    Feb 2019
    Uss
    2020 rt limited
    Dec 2013
    Need more info?! How? When? What occurred that made you realise cruise wasn't working??
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Bossier LoUiSiAna
    Stopped working or won’t set? It does have minimum requirements of speed & rpms before will set.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Make sure the brake is releasing all the way. Brake lights need to be off. Cruise will not set until you are doing about 25. Check to make sure you are not in trailer mode.
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Jul 2014
    Mint Hill, NC
    2020 RT? Anything else not work, like horn? Look at pg 145-146 of your operator's guide and check fuse #5 in Right fuse box and fuse #2 in Right JCase fuse box. Best approach, see the dealership; it's warranty work.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    RT-S PE#0060 Gordy's Avatar
    neepawa manitoba ca
    this happened to my 2010 RTS and the vehicle control modual had to be replaced
    Sep 2014
    USA
    Take it in under warranty.
    May 2013
    Apex, N.C.
    My 2014 RT used to do that any time it was in for service and put on the BUDS software. It would take about 300 miles before it would work again. Not sure what caused it, and never read about it happening to anyone else. But for my first 3 services, that was the case. But since it is new, I would just take it into the dealer. Good luck.
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I had this problem since I got the trailer harness installed ( factory harness and dealer installation) I finally figured out that it was rain water collecting I the trailer plug. I added dielectric grease and it stopped the problem.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Apr 2019
    Clinton, MS
    Quote Originally Posted by bcer960 View Post
    That was thinking outside the box.
    Jul 2016
    Kamloops B.C.
    It took a long time to diagnose because it would only happen in the rain, and mostly when the trailer was attached. But to break all that down took 2 years.....
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Oct 2014
    Fort Mill, SC
    It's like going to the dentist with a toothache. Once you sit in the chair, you can't tell which tooth is hurting.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Quote Originally Posted by Gordy View Post
    Mine too. I plan on taking it to the dealer and have them fix about 5 or 6 things that should be considered warranty work.
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    OP started a new thread here everybody!
    https://www.spyderlovers.com/forums/...pedal-sticking
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Dec 2013
    Quote Originally Posted by bluewoo View Post
    Thanks for that bluewoo!
    Helps to give a little bit of 'explanatory closure' to this thread, and lets us know the OP has maybe found out what the issue was. Appreciate the courtesy.
    Aug 2020
    Creal Springs, Illinois
    Hmmmmmm.....just got used 2020 RTL... 1k miles on it and was trying to set cruise control just today... Didn't work. Figured I was doing something stupid. I need to take a closer look.
    Jul 2014
    Mint Hill, NC
    Start at pg 22-25 of your operator's guide.
    Cognac 2014 RT-S
