Results 1 to 9 of 9
    Oct 2015
    Lynden, WA
    Spyder VTwin and Red Dust ??
    Is the red dust on the front sprocket an issue on the 998 VTwins?
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Sep 2020
    Platte City, MO
    Not on Peggy's.
    Dec 2012
    Murphy, NC
    Have not heard of any.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Quote Originally Posted by JKMSPYDER View Post
    .... and so far my 14 RT hasn't shown the Red dust ..... the first I heard of this issue was with the 2015 F-3's after about 2 yrs. and not all of them has the issue ..... IMHO this may have started because BRP changed the vendor for these associated parts .... sometimes saving a few bucks can be a BAD thing ..... Mike
    Durham,Maine
    There's on reasoning behind this sprocket thing, no one's really put there finger on the cause, bad installation, bad parts, ect!! It's to bad, and why is it seem to be only the F-3's ! For just a piece of mind it would be nice if BRP would fess up and give us some insight on this issue, they have to have a clue on the why's and what for!!! But it would take coming forward and saying we F**** up, and then they would have to fork out some money to fix it!!
    2012 RTL , Pearl
    Dec 2009
    West Oz
    It's been an issue since day 1. A year or so later BRP issued a TSB saying that the failure was due to 'insufficient clamping force' applied by the bolt at the factory and directed dealers to retorque the bolt to a higher spec then mark the head with a X to show it had been done. The TSB was 'published' on this forum at the time, probly by Lamonster. I think the latest torque spec for that bolt is 110ftlb.
    If applying lube to the spline it is critically important that the lube does not get onto the inner face of the pulley or the mating face of the shaft - just the spline only.
    Sep 2020
    Platte City, MO
    Just curious, does the bolt tighten down on the shaft, or onto the sprocket? My VFR has the bolt tighten down on the shaft, that way the sprocket is
    free to "float" a bit on the shaft. Hence the use of some kind of lube to keep wear to a minimum. I put anti-seize on the sprocket, but not everyone
    does, but the number of failed sprockets due to spline failure is minuscule.
    Dec 2009
    West Oz
    The bolt tightens onto the pulley - this provides the clamping force BRP speaks of here, way back in Dec 2009 when I got my Spyder:
    https://www.spyderlovers.com/forums/...t-BRP-Bulletin
    See post 54 for copy of TSB.
    but the number of failed sprockets due to spline failure is minuscule. but if it happens to your trike, the consequences of such a failure are far from miniscule.
    Sep 2020
    Platte City, MO
    Amen on that.
    Seems odd that sprocket tightened down like that would work loose. I wonder if that flywheel addition to the sprocket could have some bearing on it. I wonder if anyone has
    checked a sprocket for balance. Maybe if that weight was off center a bit you might have some issues. That thing is a new one on me.
