Results 1 to 25 of 27
    Default Brakefree Helmet Light
    I finally received my shipment of the Brakefree helmet light.
    They come from Hong Kong and it was in transit for 19 days. Package arrived in one piece and everything was as ordered.
    A very well put together item and larger than I thought it would be.
    The unit measures 7 1/2 inches by 3 inches. Has 100 LED's and is very bright and noticeable to others.
    The unit has a stick-on mounting piece that glues to the helmet and the Brakefree unit snaps into it. They recommend 2 - 12 hours before use. Clean helmet with alcohol wipe and place stick on unit in place.
    My Bell Magnum/Sena actually had an indented place where the unit fit into perfectly. The unit snaps into and off of the mount very easily.
    Took it out for a test drive this PM and Linda said it lit up very bright. It lights up each time you step on the brake pedal. At night, this one will be something to see.
    Cost $169.99 plus $10.00 shipping. A bit pricey IMO, but a very nice unit. I was not able to transfer a picture only. Did not want to put in an attachment to the web site as I do not want to be accused of pushing a non-sponsor product.
    I did contact the company to see if they wanted to become a SL sponsor, but have not heard back from them as of yet.
    You can find them if you want to look closer.
    Active Member juscuz's Avatar
    Dec 2015
    Virginia (US)
    Received mine months ago and very satisfied.
    Mar 2013
    Marion, Arkansas
    I wonder if this will attach to the back of my head since I don't wear a helmet in Arkansas?
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Quote Originally Posted by Ex-Rocket View Post
    If you can't find a 'strong-enough glue' that'll work, a staple gun should fix it in place just fine!
    Linden, CA
    I will make you a hell of a deal on some duct tape
    Bossier LoUiSiAna
    Secure enough you trust leaving with helmet while you not around? Say a restaurant stop or something or would remove like a headset & secure elsewhere
    Durham,Maine
    Do you have to install a switch on the bike so it knows when you hit the brake, how's that all work?
    2012 RTL , Pearl
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    i've got some nails and a nailgun!
    2021 Limited , MArsala Red & Chrome
    Aug 2008
    Maryland
    NO -it works on deceleration - so you can use engine braking
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Aug 2019
    Stoughton, WI
    https://www.brakefreetech.com/products/brake-free
    2022 RT Sea To Sky
    Durham,Maine
    Quote Originally Posted by BeRight View Post
    I did a quick search on them I found some that have directionals on them also, was Just wondering how it all worked!!
    2012 RTL , Pearl
    Durham,Maine
    Thank you for the post!! I don't think my navigator would like that light much, But I was thinking it would be a great thing for snowmobiling, wonder how it would hold up in subzero weather???
    2012 RTL , Pearl
    Sep 2014
    USA
    Or two side tape
    Dec 2018
    Long Island
    I was thinking the same and then realized if I purchased a second helmet mount I could attach it to the navigator's helmet.
    Sep 2020
    Platte City, MO
    OMG, that thing is huge.
    Mar 2013
    Marion, Arkansas
    Sep 2020
    Platte City, MO
    LOL
    Easy snap on/snap off, but I would probably put helmet in trunk. I already have about $500 into each helmet. I am very careful where I leave the helmets out, if I do at all.
    I don't know the technical stuff. A deceleration switch makes the light kick in when you impede forward motion as in brake, or slow down. The harder the braking, the brighter the light. The connection between helmet and bike is completely wireless.
    I did not get a version with the directionals. The set up is such that it would be a great idea if they could get it to work. There would be no doubt about your intentions to turn.
    Rechargeable battery just like garmins etc. I note that my garmin does not work good if the temps get over 90 degrees, have not tried cold weather operation yet.
    Quote Originally Posted by LongIsland View Post
    I am only going to buy one unit, but since I have two different bikes, and two different helmets, I have ordered a set of attachment units so I have one for the other helmet and a spare. Cost for two is $15.99 but I got them on sale for $12.99 plus $3.00 shipping.
    All the better to be seen. And you will for sure.
    Aug 2008
    Maryland
    I don't know the technical stuff. The light picks up a signal from the brakes and just goes on when the brake is applied. The harder the braking, the brighter the light. The connection between helmet and bike is completely wireless.
    NOPE: from their website: "Detects all deceleration events whether it is engine braking, downshifting, or braking" "No need to wire anything to your motorcycle or install any apps! Fully self-contained with sensors and batteries inside, just power it on and ride"
    I told you I did not know the technical stuff.
