Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
  1. #51
    If you don't use down shifting for deceleration, you're not riding aggressively. I don't think I've ever done a ride when I haven't manually down shifted at some point...
    They do this ( downshift to brake ) all the time in various types of racing ..... Guess how often they change out the transmission and clutches .... EVERY race ..... guess who pays for this ???? .... and it's .... NOT THE DRIVER..... jmho ... good luck ..... Mike
  2. #52
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I've had 3 manual trans - F3 with 23,000 miles, F3 Daytona - 19,000 miles, and F3-t with 18,600 miles. I downshift for engine braking constantly and ride aggressively, single and 2-up, and I have never had a sprocket issue.(knock on wood). My point is, I don't think downshift engine braking is an issue.
    2020 RT Limited , Petrol Blue
  3. #53
    Very Active Member Freddy's Avatar
    Dec 2009
    West Oz
    ......... and even it was the cause, as some suggest, it's a manufacturing issue not a rider issue - until you're left stranded.
    The best substitute for brains & knowledge is....................silence.
  4. #54
    Aug 2019
    Stoughton, WI
    Big shout out to JP58 (Jerry) for, honestly, doing the whole inspection/moly paste and bolt install. My 2019 F3S only has 8.2K miles and was, as expected (hoping?) clean as a whistle with factory spline lube still intact. I'll inspect every seasons end here on out. Thanks Jerry !!!
    2022 RT Sea To Sky
  5. #55
    Sep 2009
    La Valle, WI
    Your welcome. Always nice to help out a fellow Spyderlover.
    2018 F3 Limited , Oxford Blue
  6. #56
    Aug 2019
    TX
    Quote Originally Posted by DerSpyGuy View Post
    This is what you need:
    https://www.amazon.com/Loctite-23422...DV225K9KDMV3Y9
    or this (could be the same formulation, but more expensive):
    https://www.amazon.com/Anti-Seize-Mo...PRZPRV3BCTMZXC
    We are both referring to the same product. Loctite 8012 is the same as loctite 51048.
  7. #57
    Aug 2019
    TX
    Quote Originally Posted by SPYD3R View Post
    NO NO NO.....
    DO NOT GIVE BRP a reason to VOID your WARRANTEE.....
    i just spoke with my dealer, and he advise me to go with the recommended 'paste' that BRP is saying will cure the problem; KLUBERPASTE 46 MR401, is what is recommended... my dealer informed me that they had to cut a spline in half because the wrong material was applied... he also stated that the K-paste may need to be applied occasionally... i would think @ each rear tire change...
    just my opinion.... but well all know how that goes...
    Dan P
    SPYD3R
    i don't know if you're keeping score or not, but the OP used Kluberpaste or whatever and the sprocket only lasted 5k miles. I'd say that's a big hell no to that being the solution, warranty or not. I'm sticking to my loctite 8012/51048 as i don't have any confidence in anything else at this time. Time will tell what last and what doesn't.
