Lighting Wiring Diagram Needed
I need a wiring diagram for the lighting on a 2020 F3 Limited.
Thank you
You can probably find one in a service manual. https://canammanuals.com/
otherwise be a vulgar brawl.
Cognac 2014 RT-S
Originally Posted by JayBros
I have the manual and there is nothing specific
My Green Manual has one but I honestly think I'd go blind trying to read it. It appears as the last item after the specifications and before the flat rate manual.
Cognac 2014 RT-S
I have the BRP manuals. It is about the last thing in the manual, right after the tech specs. You need to be on a computer with a large screen to make any sense of the wiring diagrams. They are much too small on cell phone or a tablet. You get lost trying to follow the wires to another area.
Just to add a comment, what is it exactly you need to find out from the wiring diagram. Maybe someone has already sorted it out and can tell you.
Looking to add a universal tale as turn Module & other stuff to be seen while braking & riding.
Look at Lamonster Garage and Spyderpops products as they may have plug and play systems that meet your requirements.
Cognac 2014 RT-S
Not sure what you want, but at the connector inside the right and left bags these are the colors. Brake and Tail are the same both sides at the connectors bike side which continue under the seat. To the bulbs the colors are common on each side inside the bags. For access to these, check my page at the link in my sig.
