Results 1 to 23 of 23
    Dec 2014
    S.E. Michigan
    Default Starting Changed?
    So,I have notice that my 2016 RT-L starts right up as soon as I hit the the button on the left bar. No delay while Spyder check itself out. Had it in for a new tire earlier this month. I guess they also updated some programming? Cool!
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Durham,Maine
    Any one else know of a update on this????
    2012 RTL , Pearl
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Nope. But on my '14 I don't have to wait - as soon as the display lights up I can hit the Mode Button then start it up. It'll finish initializing while I'm getting my helmet on.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Durham,Maine
    Quote Originally Posted by Wahrsuul View Post
    Wish mine would!!
    2012 RTL , Pearl
    Mar 2015
    forrest above Reno, Nv
    Wish mine would!!
    No waiting at all with the " flash" And more HP to boot.
    Lew L
    2014 RTS , Circuit Yellow
    Mar 2015
    Indianapolis, IN
    Old Motors (998s) - you had to wait for the dash to fully boot before you could press the mode button and start it.
    New Motors (1330s) - you can press mode as soon as the screen starts booting (after DESS clears the key) and start the bike.
    If you send your ECU to Monster or Wick-It for a Flash - they can set it so you don't have to hit Mode at all to start it - and you get more HP out of the Flash.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Comment deleted. It was plumb wrong! I'll have to check again later but it looks like for the 2014 RT you can hit Mode, then Start, as soon as you see Can Am on the display. I thought you could not.
    Sep 2015
    Chilliwack, BC. Canada
    It doesn’t work on my ‘14. I have to wait. I just tried it again yesterday, but I have NOT had it in the dealers shop this year.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Quote Originally Posted by bigbadbrucie View Post
    I just tried it again. You are correct. If you restart the bike within an undetermined time span of a few minutes after shutting it down, you can push Mode, then start, as soon as Can Am shows. This has been discussed before. But after the "free start" period you must wait.
    The change was made sometime in 2015 or 2016. So Jdr00ejr's comment above is incorrect. The feature is not available on all 1330 engines, which is what I wrote in the comment I deleted.
    Durham,Maine
    Yes mine will do that, if I stop and grab a coffee and come right back out it will start up with out having to wait! After a set time it makes you wait to boot!!
    2012 RTL , Pearl
    Mar 2019
    Central SC
    Hmm, that's not what happens on my '14 - as soon as Can-Am shows up, I hit mode and start and off it goes. This is first start in the morning.
    2014 RT-S , Orange
    Interesting. Have you had your ECM updated by the dealer or otherwise flashed? If not, what time in 2014 was your Spyder built? Mine was an early production model so I wonder if the change was made sometime during 2014.
    I have found over the years with my 14 RT ..... If I shut it off for less than 12 minutes .... turn key to run and hit the start button ( leave Mode button alone ) it will start .... tryit , I'll bet yours starts also ..... Mike
    Vermont
    Mine does the same thing, I have the same year ( 2014).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Sep 2014
    USA
    Yep I can fill the tank with gas at times and when restarting I do not have to press the left button , it goes right to the MPH screen.
    I think this is the first time anyone has offered a number of how long the "free start" period lasts. I knew it was upwards of 5 minutes but have never bothered to actually time it.
    It's interesting that Wahrsuul and Deanna report they don't have to wait, ever, even when the bike has been shut down overnight. I don't find any reports of this in 2014 and 2015 posts although some, including myself, did see the startup screen get bypassed on rare occasion.
    Sep 2015
    Idaho, I’ve found with mine, 2014 RTS, that the engine has to be up to operating temperature before the whole startup procedure can be bypassed, and this would also sort of conform to Blueknight’s 12 minute finding.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    I know they said they " don't have to wait " ..... but this is AFTER the display lights up. This is the same as mine ( and everyone else's ) .... Mike
    I M S ..... 12 minutes is really my estimate ..... based on shut-off at the pump , and then fueling and going into the rest-room..... it may only be 10 minutes ...... but it's way more than 5 ...... jmho ..... Mike
    Northern Kalifornia
    On my 14 I can shut it off, then hit the ECO/MOD button and the radio will continue to play. I can continue to listen to the radio through my Sena helmet speakers when I fuel up or go into the post office. When I get back there's no wait time for startup. However, the start screen goes into a rainbow mod for a couple of seconds.
    Durham,Maine
    This is weird it seems we all have a different set up, or procedure!! What I do know is they could do away with it in my book, it's one of those things that piss you off that you wish you could fix! It's like I just got a new Silverado 1500, it had the auto stop feature, that stops the engine when you come to a stop in the street!! I had a switch on the dash that I could hit EVERY time I started the truck that would shut that feature off, but when I shut it off and start it back up it would reset After about a week of that, I went online a found a company that made a fix for my problem, now I command when the darn things on or off!!!
    2012 RTL , Pearl
    Mar 2019
    Central SC
    Since I got mine used a little over a year ago, I can't say if the ECM is upgraded or not. I know the gauge cluster was swapped out before I got it. It hasn't been to the dealer since I bought it. I'd have to look to see what time it was built.
    2014 RT-S , Orange
    Aug 2019
    southwest oHIo
    I know most of the discussion here after the first poster has been about '14s and '15s, but I'll offer that our '17 RT-S, which was assembled in May 2016 (yep, serial #55 ) does not force a long wait to start. Turn the key ON, find the MODE button, press it, press the starter. I think I remember reading in the manual that if you start the bike within five minutes of turning it off, you do not need to do that, I have not yet verified. One owner before us, he assured us it was all bone-stock, no modifications. Not sure about dealer-instigated BUDS updates, though.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
