Results 1 to 13 of 13
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Default Drink holder options on a 2021 RT LTD?
    Well now I need to see about a new drink holder, my revco doesn't seem to be high enough now vs the 2018.
    Any suggestions???
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    https://www.drink2go.com/
    I have the Spyder2go and drink2go pair. The Spyder2go is a one bolt mount to the left grip, and the drink2go clamps to the rear handgrip.
    Works well for me
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
    Aug 2008
    Maryland
    I like the ram ball self leveling cup holder - haven't purchased one yet for RT - loved it on my F3. They range from $19 up based on mounting.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    Aug 2020
    Hawthorne, NJ
    Quote Originally Posted by Stache View Post
    Works well for me
    Same here on a 2020 RTL but does yours hit the dash at full right turn?
    Apr 2020
    Flatrock, NL, CA
    Quote Originally Posted by vrich3733 View Post
    Yes, but I’ve checked angles with it on and off. Not losing significant steering, especially since I only go to the limit in slow speed manoeuvre like parking.
    I allow for it, and don’t jam it to the stop
    ‘20 RTL Stone Grey
    Farkles:
    Bestem Carplay
    trunk organizer,
    Nautilus horn
    Convex mirrors
    Farkles
    frunk organizer
    dual horn
    Max mount
    Side bag
    Top bag
    Sep 2013
    Houston
    DO NOT mount drink holders to the back of the handlebar control cluster. You will be replacing the cluster and its a very expensive repair. Those screws go into a small brass insert that is just pressed into the plastic housing. They cannot support the weight of a drink bouncing down the road. We have had to replace several of these for customers that were duped into purchasing this faulty design product.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2015
    Dorr, michigan
    Works well for me
    mine work perfect. I have 2 of the clamp on style and clamped it to the handle bars, and to the grab rail for the passenger.
    2020 RT Limited , Petrol Blue
    Feb 2020
    N. Wilkesboro, NC
    http://www.lamonstergarage.com/can-a...lamonster-ips/
    Best and IMHO the ONLY suitable solution if you want a drink on your handlebars (F3 and 2020+ RT).
    Sep 2018
    greensburg,pa
    Thanks for all the advice everybody! I ended up getting a RAM mount $25.00 clamp on style and will see how it holds up. I have a local motorcycle accessory shop that had it.
    2018 RT-L , Blue
    Mar 2019
    NEBRASKA
    I have drink 2go on both RTs left cluster....dang. Would it help if use loctite? Or just get them outta there? I really like them but replacing a cluster doesnt sound like fun or cheap.
    2012 RTL 14 RTS , Pearl White @ Pearl White
    Sep 2018
    greensburg,pa
    Quote Originally Posted by davev1pa View Post
    Not sure what your asking davev1pa? The type I had on the 2018 RTL I had on the right handle bar cluster, But I found out it wont clear the speak covers on the 2021 model so I got this pretty cheap and it benn working great.
    2018 RT-L , Blue
    Dec 2013
    See the BOLD bits!! Loctite WILL NOT help at all!
    Bluewoo's 'Clamp On' style units are much less damaging!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2013
    Houston
    loctite will not help. Take them off before they damage the cluster. Its a defective design.
