Results 1 to 6 of 6
    Jan 2020
    Cluj-Napoca, Romania
    Default 2013 Spyder 156hp is it possible?
    Hello,
    I just read an add with a 2013 Spyder 990cc engine, 156hp and I wonder if this can be done and how. Remap the ECU, turbo kit added or what.
    thx
    Sergiu
    Mar 2015
    forrest above Reno, Nv
    If the hot rodders can get 500+ horse power from a Hayabusa------ then its possible, not pretty though.
    2014 RTS , Circuit Yellow
    Feb 2020
    N. Wilkesboro, NC
    With enough money, almost anything's possible.
    Dec 2013
    These Rotax 998cc engines are used in other 'non-Spyder' applications with better numbers than that straight out of the box; so YES, even with not much more than an air intake & exhaust upgrade plus a good ECU map upgrade, it's certainly possible to achieve that sort of output!
    However, given the above, I'd expect somewhat better results from a well thought out turbo installation!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2017
    Durham,Maine
    OH ya turbo, gag the nanny, tire burning rocket!!! Slick, wheelie bar******!!! Hew, I am alright now,,,,,
    2012 RTL , Pearl
    Feb 2020
    Sheridan, Wyoming USA
    Aprilia got over 130 HP from the 998cc Rotax in their Tuono and the 995cc Ducati twin is 155 HP, so 156 is certainly achievable with some hotter cams, free-flowing intake and exhaust, a good ECU tune, some judicious cylinder head polishing and porting, larger valves, and balancing and blueprinting internals to allow higher RPMs. Or a small turbo, free-flowing exhaust, and a tune would get there as well. I'd be more inclined to just start with a more potent existing engine and find a way to make it fit.
