Using a motorcycle jack for an RTL ...
Can I?
Or should I sell the jack with my Venture?
I use mine all the time. Just forward of the cat springs.
Thank you so much. Appreciate it.
Holy Moly ... look at your map!
Thats awesome. I want mine to look like that when I grow up! I'll be you have a lot of stories.
Thanks again
I used mine to replace the front wheels/tires on the wife's RT...needed to drive the front tires up onto some 2-bys to get enough clearance to get the jack under, but it worked a treat.
Thanks again
If he wants to impress me, he'll have to add Hawaii.
I use my Torin BigRed motorcycle jack for my RTL, the problem is it just a tad too low for the jack where the frame is. So I just drive the two front wheels atop a 2x6 and there would be enough clearance for the jack to go in. That 1500lbs jack can lift the RT to the max without any problems.
‘21 Honda Rebel 1100 DTC Burgundy
‘13 Spyder RT-L Pearl White
