Results 1 to 7 of 7
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Using a motorcycle jack for an RTL ...
    Can I?
    Or should I sell the jack with my Venture?
    2021 Limited , MArsala Red & Chrome
    Mar 2013
    Maumelle, AR
    I use mine all the time. Just forward of the cat springs.
    2020 RT Limited , Chalk
    May 2020
    Rhode Island
    Quote Originally Posted by Copperman View Post
    Thank you so much. Appreciate it.
    May 2020
    Rhode Island
    Holy Moly ... look at your map!
    Thats awesome. I want mine to look like that when I grow up! I'll be you have a lot of stories.
    Thanks again
    Feb 2020
    Sheridan, Wyoming USA
    I used mine to replace the front wheels/tires on the wife's RT...needed to drive the front tires up onto some 2-bys to get enough clearance to get the jack under, but it worked a treat.
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Mike0123 View Post
    Thanks again
    If he wants to impress me, he'll have to add Hawaii.
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    I use my Torin BigRed motorcycle jack for my RTL, the problem is it just a tad too low for the jack where the frame is. So I just drive the two front wheels atop a 2x6 and there would be enough clearance for the jack to go in. That 1500lbs jack can lift the RT to the max without any problems.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
