Results 1 to 12 of 12
Hybrid View
    Active Member Mike0123's Avatar
    May 2020
    Rhode Island
    Default Heated gear power cords
    Can I put the Gerbing plug leads directly to the battery on a 2021 RTL, like on my bike?
    Thanks ... gotta keep the bride warm!
    Mike
    2021 Limited , MArsala Red & Chrome
    I do not know any details of the 2021 wiring but directly to the battery is the only place I would put them on my '14 RT-S. I'll wager the '21 wiring is essentially the same as the '14.
    May 2020
    Rhode Island
    Makes sense. Thank you
    Jul 2015
    Dorr, michigan
    That is what I just did on the 2020.
    2020 RT Limited , Petrol Blue
    Feb 2012
    Spring City,Utah
    that is the only place Gerbing recommends
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Northern Kalifornia
    Be sure and fuse your lead.
    Sep 2018
    greensburg,pa
    Back of the alternator is closer.
    2018 RT-L , Blue
    Quote Originally Posted by bluewoo View Post
    Not trying to be picky here, but back in the day I was taught that connecting anything electrical besides the battery straight to the alternator risked destroying the alternator & maybe more if you blew up &/or shorted whatever you'd connected that way, potentially even if that connection was fused!! And I've certainly seen a few auto & 4WD alternators (& vehicles too!) destroyed that way!!
    By connecting relatively high demand devices like your heated suits to the battery via a fused connector instead, my understanding is that you should not only be protecting the alternator from damage, but just so long as your total load on the system isn't above the electrical system's peak capacity, you'll also very likely be 'ironing out' any potentially fuse blowing spikes in demand/supply as things get turned on &/or off & the electrical demands vary!! The battery effectively acts as a secondary fuse/circuit breaker (I reckon it IS generally cheaper & easier to replace a battery than it is an alternator! ) and it'll also act as a big 'shock absorber/spike leveller' for the entire electrical system.... but by connecting anything direct to the alternator, you risk feeding all the power fluctuations & any spikes directly back into the most critical component of your charging system!?!
    So maybe it'd be better to connect your heated suits either directly to the battery, or to an otherwise isolated & protected fuse block/circuit breaker that's connected directly to the battery specifically for your suits?!
    Just sayin'
    Sep 2018
    greensburg,pa
    For me its safer not having a + cable anywhere around the steering system not much room. From experience I am confident that my set up would not cause an issue and hasnt for years. No way the heated gear would over amp that + battery cable or a spike would be any different from the same cable 2 feet away.
    If your old enough the starter relay on the fender was the popular + tie point and now on all electric fork trucks/pallet jacks... you tie into the first point of the positive and negative and that's on the main control boards not the battery it self.
    *I think the "connect directly to battery is a legal protection statement too not have us tie into a small gauge + wire like the 12v in the trunk of the 2019 and older models or anything else.
    Its also just a jacket the boss wears and I agree if your going full heated everything the of course a separate power point makes sense.
    No problems with a healthy conversation right
    2018 RT-L , Blue
    Jul 2018
    Nw wi
    Have one connected to battery 17 RTS. Jacket gloves insols. Works great. It doubles as my battery tender connection also.
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Mine is to the battery
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    May 2020
    Rhode Island
    Thank you all!
