Results 1 to 9 of 9
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    Default Exhaust - how much louder will it be with OE muffler & Cat Delete?
    I have a 2020 RT and would like to remove the cat and replace with
    a cat delete pipe . My question is how much louder would the exhaust
    be with factory mufflers in place? Opinions appreciated!!
    Dray
    Quote Originally Posted by Dray View Post
    Dray
    On 14 RT I did the CAT delete with added Baffle..... only a small difference in sound ( better ) I love my tunes and the change wasn't bad ..... Mike
    Aug 2020
    Shenandoah Valley
    '20 RTL with Lamonster delete pipe, baffle inserted. I think it's only a tad "throatier," but it's still almost OEM quiet. I barely notice any difference.
    Aug 2018
    north wis
    20 RTL with RLS delete,hardly any louder.I do get better mpg.
    May 2013
    Apex, N.C.
    I just did the cat delete on my 2016 F3T. I did not put in the baffle, and it is slightly louder at idle, but quite a bit when going down the road. I have been considering adding the baffle, but the added power above 3k rpms is so nice that I don't want to mess it up. I have heard that if you add the baffle, and then decide to take it out, it will be very tough. I do miss a little off the line tq., but it is hardly noticable. I plan on doing a flash one day, so that is another reason for leaving the baffle out for now.
    Aug 2019
    Stoughton, WI
    I have a Baldwin Ironworks cat delete pipe, which is basically identical to the Lamonster pipe. I also have my stock muffler. Baldwin recommends running the baffle in. I tried it all ways with baffle/plug/baffle/no baffle. I "prefer" the baffle only. I did recently order a spare baffle, which I intend to cut in half. Maybe find a happy medium? I also have a Power Vision 3 with a custom tune. We shall see....
    2022 RT Sea To Sky
    Aug 2020
    Shenandoah Valley
    Baldwin identical, except, Lamonster is a C-Note more expensive and doesn't send a spring wrench. I almost went with the Baldwin instead. I am usually of the court that you get what you pay for... but dunno in this case.
    On the surface, I saw that the BI baffle has a bolt, Lamont's did not. I didn't want to risk a bolt rattling around inside the exhaust if it loosened. So.... I dunno... I doubt the Franklin was worth it, and would like to know if it was..?
    Feb 2019
    Portland, Oregon
    I have the RLS Exhaust delete with the resonator, but I did not insert the secondary baffle. The sound is smooth (not raspy like most) and throatier, but NOT louder. Even non riders compliment the sound.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Truckie View Post
    I actually stopped by Baldwin's house/shop on a ride to the Ozarks this time last year. He assembled the pipe on site, installed it and mailed my big ass cat back to WI for $200 cash. The quality is excellent, with very nice welds. He offered to polish it, but I said no worries, as my buddy/I were heading to Branson/Eureka Springs that day. I'm very happy with the cat delete pipe.
    2022 RT Sea To Sky
